Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
09-03-2015, 21:45 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Phone is Qualcomm platform, only way is to change PID, and use OTU updater. If u are skilled enough, I can give needed toolz, otherwise, you can end with totally bricked phone. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
01-12-2016, 21:03 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
editing it and pushing back to phone. Phone needs to be rooted. Or, try with OTU Updater, when it puts phone to download mode, if in device manager you can see "Qualcomm eMMC storage" under DISKS, than eMMC RAW application can be used for read/write partitions. take a try. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
01-13-2016, 12:32 | #5 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
there is no partition like u say.. partition not listing by-name.. root@android:/ # ls -l /dev/block/platform/msm_sdcc.2/by-num ls -l /dev/block/platform/msm_sdcc.2/by-num lrwxrwxrwx root root 2011-01-01 04:04 p1 -> /dev/block/mmcblk0p1 lrwxrwxrwx root root 2011-01-01 04:04 p10 -> /dev/block/mmcblk0p10 lrwxrwxrwx root root 2011-01-01 04:04 p11 -> /dev/block/mmcblk0p11 lrwxrwxrwx root root 2011-01-01 04:04 p12 -> /dev/block/mmcblk0p12 lrwxrwxrwx root root 2011-01-01 04:04 p13 -> /dev/block/mmcblk0p13 lrwxrwxrwx root root 2011-01-01 04:04 p14 -> /dev/block/mmcblk0p14 lrwxrwxrwx root root 2011-01-01 04:04 p15 -> /dev/block/mmcblk0p15 lrwxrwxrwx root root 2011-01-01 04:04 p16 -> /dev/block/mmcblk0p16 lrwxrwxrwx root root 2011-01-01 04:04 p17 -> /dev/block/mmcblk0p17 lrwxrwxrwx root root 2011-01-01 04:04 p18 -> /dev/block/mmcblk0p18 lrwxrwxrwx root root 2011-01-01 04:04 p19 -> /dev/block/mmcblk0p19 lrwxrwxrwx root root 2011-01-01 04:04 p2 -> /dev/block/mmcblk0p2 lrwxrwxrwx root root 2011-01-01 04:04 p20 -> /dev/block/mmcblk0p20 lrwxrwxrwx root root 2011-01-01 04:04 p3 -> /dev/block/mmcblk0p3 lrwxrwxrwx root root 2011-01-01 04:04 p4 -> /dev/block/mmcblk0p4 lrwxrwxrwx root root 2011-01-01 04:04 p5 -> /dev/block/mmcblk0p5 lrwxrwxrwx root root 2011-01-01 04:04 p6 -> /dev/block/mmcblk0p6 lrwxrwxrwx root root 2011-01-01 04:04 p7 -> /dev/block/mmcblk0p7 lrwxrwxrwx root root 2011-01-01 04:04 p8 -> /dev/block/mmcblk0p8 lrwxrwxrwx root root 2011-01-01 04:04 p9 -> /dev/block/mmcblk0p9 root@android:/ # tell me which name will i search in that partition over hex..? device info; 995X-2CTNE3-S50 | |
01-13-2016, 20:32 | #6 (permalink) | |
maybe try dumping one by one, and you will easily find out which one is it. When opened in notepad++, you will find (via ascii search), inside, your PID - 995X-2CTNE3 When you locate it, I will give you PID list to put/change existing, and after you can write back to phone and try OTU Updater. b.r. Alex
01-14-2016, 03:42 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | I just found out, that ot-995, when switched to download mode, has eMMC visible and mounted. Try to put it to download mode, with OTU Updater (when it starts reading handset, it will power it off, then disconnect cable, and force-close OTU Updater), after use eMMCRaw utility to read / write partitions. download emmc tool - HERE I also attached you my traceability partition .... open it with notepad++ and look at the structure. when writing partition back, manually write address, it's in file name, start / length. be carefull not to overwrite boot partition ! now, PID's with ARABIC : Code: 995X-2[X=A,B,C,D,F]ALTN1 -- Tunisia 995X-2[X=A,B,C,D,F]ALEG1 -- Egypt 995X-2[X=A,B,C,D,F]ALOM1 -- Oman 995X-2[X=A,B,C,D,F]ALDZ1 -- Algeria After done, use OTU to update to changed PID. You will know it worked, if it starts updating Always fully charge battery before start experimenting. p.s. My mistake, traceability partition is 1Mb in size. p.s.2 From ADB, that should be Partition 6 (?) b.r. Alex
01-14-2016, 10:42 | #8 (permalink) | ||
i didnt find the PID in my or in ur file.. traceability partition is mmcblk0p13 (1mb) it is the same with ur part.. but as i say i didnt find the PID text.. can u pls share ur PID in notepad++ or hex editor..? | ||
01-14-2016, 21:30 | #9 (permalink) | |
b.r. Alex
01-15-2016, 12:04 | #11 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | server is very slow.. i have 100mb internet connection 10mbp/s but still too slow.. is it normal or another pb..? it started %20, after 2 hours it is %25.. |
The Following User Says Thank You to LoveLess For This Useful Post: |
01-15-2016, 16:25 | #12 (permalink) | |
Just be patient... And i hope you charged baterry fully. B.r Alex
02-24-2018, 02:36 | #13 (permalink) | |
Freak Poster Join Date: Mar 2015 Location: Nairobi
Member: 2358876 Status: Offline Thanks Meter: 78 | Help me with OT-995X UPGRADE TOOL Quote:
Help me with link to alcatel one touch upgrade q 2.7.1 Cant find it I have OT-995 stuck on logo Any custom rom install successfully but phone still reboot | |
