Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
03-06-2015, 21:14 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
it is for Balkans region, and should have Macedonian language inside. b.r. Alex | |
03-07-2015, 06:03 | #4 (permalink) | |
Junior Member Join Date: Jul 2014
Member: 2218361 Status: Offline Thanks Meter: 2 | Quote:
03-07-2015, 17:50 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | If phone is dead, disassemble it, check battery voltage, If needed charge via external source, Reconnect, hold volume up + power on for 5-10 seconds, Should appear as forced download mode. If still refuses to flash, you have hardware problem B.r. Alex |
03-08-2015, 19:20 | #9 (permalink) | |
there is possibility that you don't have 6030x, but some similar model, 6012x, 6037x, etc. (or maybe someone write incorrect flash in it) those alcatels are hard to identify without original stock box. one more way to identify them is via reading pro_info file, there is written inside model and pid. or use "get boot info" on some of commercial boxes. or ... read otus_log.txt from OTU folder, there is info inside, what software read from phone, example : Code: The phone's cu is 5020X-2ATNRS3 The phone's IMEI is 8630xxxxxxxxxx The phone's version is AAXFUX0 The version in the server is NULL if phone hardware is okay. There is no any "hardware lock" that should disallow SPFT to flash firmware from other region into phone, as long as hardware is the same. (ie: in 5020x can be flashed dual-sim firmware from 5020D, etc.) b.r. Alex Last edited by Brka; 03-08-2015 at 19:26. Reason: added some info. | |
The Following User Says Thank You to Brka For This Useful Post: |
03-08-2015, 20:28 | #11 (permalink) | |
Ok, get original ROM file - HERE You will need to manually select 2 unticked files - custpack and mobile_info, from unpacked rom folder. If it still refuses to flash, well ... that's not software problem. try also forced download mode (volume up + power on for 5-10sec. then connect cable), and start flashing. b.r. Alex Last edited by Brka; 03-08-2015 at 22:00. Reason: added links. | |
03-08-2015, 23:44 | #12 (permalink) | |
02-09-2017, 17:22 | #13 (permalink) | |
Freak Poster Join Date: Jul 2015 Location: Macedonia
Member: 2430631 Status: Offline Thanks Meter: 40 | Quote:
Tried format no good | |
02-09-2017, 18:27 | #14 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Deselect userdata and cache after loading scatter. Retry operation. If still the same, make full backup, And format phone without preloader, Then retry flashing. B.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
02-09-2017, 19:04 | #15 (permalink) | |
The phone if from T-mobile Macedonia your rom should work, but it doesn't A wonder what else to try.... p.s Also tried "Firmware Upgrade" and it says "Unrecognized Rom" | |
