Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
03-03-2015, 22:24 | #1 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2356461 Status: Offline Thanks Meter: 0 | My 4007D is totally dead :/ plz help me |
03-04-2015, 20:06 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
I already posted everything needed. Lets try again : 1. Charge battery of your phone, preferably on some external source, or other phone (should have at least 3.8v) 2. Download SPFlashTools - HERE 3. Download ROM files - HERE or HERE - Unpack SPFT, Unpack ROM File(s). - Start SPFT, scatter-load, select scatter file from ROM folder - Check if all files are ticked, if not - select them manually - Press DOWNLOAD, and connect powered off phone to cable (if you don't have drivers - install THIS ) If SPFT report some errors - then you have HARDWARE problems, or your phone is not 4007D, but some other model. b.r. Alex | |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
03-05-2015, 20:57 | #4 (permalink) | |
try other pc, charge battery, try other cable, or try hardware repairing. b.r. Alex | |
The Following User Says Thank You to Brka For This Useful Post: |
03-16-2015, 15:50 | #6 (permalink) |
Junior Member Join Date: Jan 2015 Location: Pakistan ajk bhimber
Member: 2334192 Status: Offline Thanks Meter: 3 | i already explain that these rom are corrupted because i have same error when i flash it in alcatel 4007d but alex says your hardware problem change pc change window what so ever but when i download a rom from another site it flash it the arabian rom has two corrupted file i:e preloader and boot file but oher files are flashed one by one |
The Following User Says Thank You to waqar2989 For This Useful Post: |
03-16-2015, 18:08 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Then dont flash preloader and dsp_bl, Besides them, important is uboot, logo, custpack and system. or you can combine preloader + dsp_bl from other rom, it just needs to be from same model. Phone should power on with that combination B.r. Alex Last edited by Brka; 03-16-2015 at 23:00. Reason: added more info. |
03-19-2015, 14:36 | #10 (permalink) |
Member: 2334192 Status: Offline Thanks Meter: 3 | all the flash are flashed in 4007d except preloader so phone not on i try nuber of preloder file but say you do not have dsbl so format it i format but same error |
03-19-2015, 22:42 | #11 (permalink) | |
there is all needed data to revive 4007-X/D model. b.r. Alex | |
