Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 04-18-2015, 19:10   #31 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by microtech1988 View Post
brother what kind of flasher to be use for your given rom...
My favourite is v3.1344.0.212 - download HERE
Download attached scatter file, load it into SPFT - button "Scatter Loading",
then go to pull-down menus, "Window", then "Write Memory",
new tab appears, click on it, then "Open RAW Data", select rom_0 file (unpack downloaded .7z archive),
then select eMMC, and finally - press "Write Memory", and connect powered off phone to cable.
b.r.
Alex
File Type: txt MT6577_Android_scatter_emmc.txt (532 Bytes, 465 views)
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 04-20-2015, 04:48   #32 (permalink)
Member: 1881815
Thanks Meter: 9
b.r.
Alex
whats thr begin address sir (hex) and the container length (hex)
Old 04-20-2015, 07:45   #33 (permalink)
Member: 2163928
Thanks Meter: 4
thanks for the clue
this one is not glued... time for some action!
Old 04-20-2015, 12:14   #34 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Beginning is 0x0000000 , end is shown when file is loaded,
But as i remember, no need to put end address
__________________
Old 08-24-2015, 21:11   #35 (permalink)
Member: 2437453
I have the same problem.
Old 08-24-2015, 21:18   #36 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by sabcom View Post
alcatel one touch idol 6030x The slot has been permanently locked what is the solutions?
please help ,
thank in advance
Reflash firmware or use OTU Updater. It should ask for code again.
b.r.
Alex
__________________
Old 10-09-2015, 07:46   #37 (permalink)
Member: 2411203
Thanks Meter: 5
what if the error is PMT is changed...it should be downloaded.. what the solution.
Old 10-09-2015, 19:43   #38 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Usually FULL FORMAT helps in those cases,
and that error means that memory map in phone is mismatched
with one you're trying to download, or ... scatter file is wrong.
b.r.
Alex
__________________
Old 01-26-2016, 15:01   #39 (permalink)
Member: 2521054
Hello to all,
I have Alcatel 6030x VIP Serbia, and it is stuck at VIP logo on boot up.
I've tried Brka's instruction with FULL Repair ROM (Serbian ROM), flashable via WRITE MEMORY option, and i got ERROR "s_da_sdmmc write_failed(3149)".
I've also try to download TWRP recovery but without success.
Can you help me?
What can be my next step to try?
Old 01-26-2016, 16:02   #40 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
eMMC (flash memory) is dead.
No software can help.
B.r.
Alex
__________________
Old 01-31-2016, 12:56   #41 (permalink)
Member: 2185813
Alcatel OT-6030x firmware
Hello,
I need firmware for 6030x-2dbhba1?
Old 02-01-2016, 23:27   #42 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by h@ri View Post
Hello,
Read thread from beginning, and use SEARCH next time.
b.r.
Alex
__________________
Old 03-16-2016, 17:38   #43 (permalink)
Member: 2546901
how can i flash my 6030x with that 0 Rom ? my phone just connects to pc and disconnects... and i could use some 100% good scatter file for 6030x Serbia VIP... or some detailed explanatio how and what... im now very skilled with flashing or anything...
Old 03-22-2016, 12:18   #44 (permalink)
Member: 2330248
Your last hope - full rom_0 backup, which should revive your phone(s).
Download it - HERE
Use it with SPFT, tab "Memory Write". (load 6030x scatter before)
p.s. If still the same error - eMMC is dead (although it shows alive in yur memory test).
b.r.
Alex
thanks for help ,but plz can u explain how to flash phone using rom_0 ,cuz i dont konw how
thanks in advance
Old 03-25-2016, 18:08   #45 (permalink)
Member: 1663283
destroyed alcatel 6030x
hi guys ,i m wondering if any one can give the golden point to revive this fone on pcb ,
the fone was flashed with wrong flash file and the preloader file is destroyed ,so i need the test point to force boot
thanks in advance
Page generated in 0.21852 seconds with 9 queries
