Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
11-18-2015, 20:46 | #31 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
I Revived One Wrongly Flashed Dead Last edited by Brka; 11-18-2015 at 21:28. Reason: removed unnecessary formatting | |
11-18-2015, 21:15 | #32 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | If OTU Cant read it, and SPFT cant start flashing, none backup can help. You revived phone which don't have buggy cpu+emmc, so you are very lucky. p.s. Don't give wrong info's if you don't know the case and all related things about 7040/7041/7047 models. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 11-18-2015 at 21:28. |
11-18-2015, 21:22 | #33 (permalink) | |
I Need A Chance To Work On It Mine Also Dead With Wrongly Flashed By Me No Flashing Starts No USB Port But I Recoverd Luckily With Some Tricks Last edited by Brka; 11-18-2015 at 21:26. Reason: removed unnecessary formatting | |
11-18-2015, 21:26 | #34 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
Alcatel service cant fix it, too, they swap/exchange whole phone motherboard. I had one screwed phone in my hands, tried everything possible, simply NO WAY. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
11-24-2015, 15:13 | #35 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Poland
Member: 112498 Status: Offline Thanks Meter: 33 | Quote:
Emilkawa | |
11-24-2015, 17:43 | #36 (permalink) | |
B.r. Alex
11-24-2015, 21:33 | #38 (permalink) | |
b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
11-25-2015, 13:18 | #41 (permalink) | |
Thanks for your help, Emilkawa | |
11-25-2015, 13:29 | #42 (permalink) | |
I don't know how to write this memory back yet, but hope you can write me this. Regards, Emilkawa. | |
11-30-2015, 18:30 | #43 (permalink) | |
Open SPFT, go to scatter-loading, load scatter from that folder, pro_info should be automatically loaded, just press download and connect powered off phone to cable, wait to finish, and use OTU Updater after. If that fails for some reason, then same procedure, scatter+pro_info in same folder, Open SPFT, load scatter, go to drop-down menu "Window" click "Write Memory", new tab appears, "Write Memory", go to it, select "Open Raw Data", load pro_info, select "eMMC", set addresses : start address : 0x1100000 , length : 0x300000, press "write memory" and connect powered off phone to cable, after finished, disconnect, start OTU Updater and follow instructions. p.s. your current pid is : 7041X-2BALNL1 Attached : edited pro_info with these two PL pid's : 7041X-2AP7PL1 7041X-2ATBPL1 b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 11-30-2015 at 18:41. Reason: added files | |
12-03-2015, 00:19 | #45 (permalink) | |
Like on 7040/7041 models. No known way to repair it. B.r. Alex
