Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
01-18-2015, 08:03 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Moldova Age: 39
Member: 1083142 Status: Offline Thanks Meter: 51 | Need firmware ot-4007x one sim Thanks in advance!!! |
01-18-2015, 21:08 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
and edit it, as described in sticky thread (use PID from back sticker, and edit those described characters, flash to phone, and use OTU updater.) b.r. Alex | |
01-18-2015, 21:39 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Hell
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | Have u try ******************** EDIT: promoting other sites and passworded files is not allowed here. (plus, it's the flash file from commercial box, and password is incorrect.) Last edited by Brka; 01-19-2015 at 01:21. Reason: promoting other forums/sites. |
01-19-2015, 01:24 | #4 (permalink) | |
if you really wanna play, HERE is the original flash file and SPFlashTools - HERE it's not the PID you wanted, but 4007X-2AVDZA1. if you don't like customizations/languages, download attached scatter file and edited pro_info with pid you wanted (I edited it for you), and flash all together in phone, later use OTU updater, it should restore to that pid you want. If SPFT doesn't load all files (all should be marked) - do it manually, click on right side and select file from flash folder. p.s. ALWAYS make full ROM_0 backup, search this sub-section of forum, how to do that. b.r. ALex. Last edited by Brka; 01-19-2015 at 01:35. Reason: added files | |
The Following User Says Thank You to Brka For This Useful Post: |
01-20-2015, 08:56 | #5 (permalink) | |
Member: 1083142 Status: Offline Thanks Meter: 51 | Quote:
01-20-2015, 22:51 | #6 (permalink) | |
Use flash I provided, flash it to phone, edit pro_info as described in above link, edit scatter file, remove "__NODL_" in front of PRO_INFO, flash pro_info together with that flash, and AFTER, use OTU Updater, it will FULLY RESTORE imei, software, and everything, to stock, as the phone is brand new. b.r. Alex | |
01-21-2015, 11:55 | #7 (permalink) | |
PRO_INFO - Download - 4shared - Eduard Petrovschii Last edited by Brka; 01-21-2015 at 18:36. | |
01-21-2015, 18:36 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Bro, is it really so hard to read and understand sticky thread ? in pro_info for 4007x there is this string : 58JA04BLAIXSC74SAA2770AA11C06A1 C74 is android version - change it to some LOWER number - ie: B47, edit (if needed) PID - to reflect the one on the sticker in pro_info : DIX4007X-2AVDZA1 flash it to phone and use OTU updater. b.r. Alex |
01-22-2015, 08:00 | #9 (permalink) | |
01-22-2015, 20:08 | #10 (permalink) | |
You also forgot which android version was phone originally, maybe that's why wrong edit of pro_info. b.r. Alex | |
01-23-2015, 08:50 | #11 (permalink) |
Member: 1083142 Status: Offline Thanks Meter: 51 | Same error! May be i do anything wrong? i format whole except bootloader, when flash preloader, dsp_bl and pro_info, but when i load file pro_info Flash tool says PRO_INFO is too large and causes region overlap. Then i run Mobile Upgrade S 4.1.3 and program says No greater software found for my phone, what is this? |
01-23-2015, 21:43 | #13 (permalink) | |
rar/zip it, and attach/upload it here/mediafre/4shared, I wanna see it / add to collection. b.r. Alex | |
01-25-2015, 07:10 | #14 (permalink) |
Member: 1083142 Status: Offline Thanks Meter: 51 | Same error, but why i flashed file for DIX4007X-2AVDZA1 and phone not update with Upgrade tool? There is file for DIX4007X-2DRGMD3 PRO_INFO - Download - 4shared - Eduard Petrovschii and help to me reanimate my phone please? |
01-26-2015, 17:18 | #15 (permalink) | |
restore phone with "D" Model, and just flash System and Custpack, from 4007x, you will have working phone. if you need specific pid, kep playing with pro_info files, I cant help any more. b.r. Alex | |
