Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
01-27-2015, 16:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: THREE STARS AND A SUN
Member: 1208596 Status: Offline Thanks Meter: 23 | need ot 5035e firmware... 2 units on hand both dead but still detected by pc.. i try update tool no luck |
01-27-2015, 19:40 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,783 | Quote:
5035E, only 2 PID's available : 5035E-2[X=A,B,C,D]SPPH1 5035E-2[X=A,B,C,D]C2PH1 both for Phillipines area, if I am not wrong. you wrote, that you tried OTU updater, without success, now - what it means ? it wont start update or what ? please describe more your problem. what else can you do .... you can read pro_info file from phone and post here, start address is 0x2ce0000 , length is 0x80000 (5Mb) search my topics, how to read pro_info, I attached scatter file for 5035(e). if it wont read ... then you have hardware problem. try to use memory test from SpFlashTools, if eMMC is not detected - you have dead eMMC chip. you can also try writing ot-5035D rom, phone should power on with it. download rom file HERE and SPFlashTools HERE. b.r. Alex Last edited by Brka; 01-27-2015 at 19:42. Reason: added files | |
The Following User Says Thank You to Brka For This Useful Post: |
02-22-2015, 22:01 | #4 (permalink) | |
Download as zip, or file-by-file, put all in one folder, Download SPFlashTools - HERE Start SPFT, load-scatter, and manually select ALL files, that are not ticked (selected), in lower part of SPFT window Press Download, and connect powered-off cable to phone, wait for it to finish. After done, you should have working phone. It's for 5035E, Philipines ROM, as I could see. p.s. If you get wrong / missing imei after flashing, edit scatter file, remove __NODL_NVRAM (__NODL_NVRAM 0x130c000), it must be like this : NVRAM 0x130c000 Save scatter, and manually select nvram partition. After flashing all that, it should be 100% ok. b.r. Alex Last edited by Brka; 02-22-2015 at 22:07. Reason: added some info | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
09-13-2015, 21:11 | #6 (permalink) | |
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
