Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
03-22-2015, 15:33 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 74
Member: 1323797 Status: Offline Thanks Meter: 154 | Alcatel 4007x hang at logo i have alcatel 4007x with hang on logo.i did read the scater file from same working phone. but when i try to flash with sp flash tool its give me this error BROM ERROR;S_FTHND_FILE_NOT_LOADED_YET (5007) PLZ HELP ME TO SOLVE THIS PROBLEM |
03-22-2015, 23:44 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
03-24-2015, 06:55 | #5 (permalink) | |
Member: 1323797 Status: Offline Thanks Meter: 154 | Quote: | |
03-24-2015, 07:39 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | You can clone the working phone, and write it to dead phone. Open scatter file in text editor, check address of "cache" partition, Open spft, load scatter file, Use that cache address as length under "memory read" tab, select save location, Press read, connect working phone, wait to finish. Now for dead phone - load scatter file, and do full format. Under memory write option, load that readed file, select emmc storage, Press write memory, connect dead phone, wait for writing done, Power on phone in recovery mode, volume up + power on, do wipe data/cache, And after reboot, you should have working phone. B.r. Alex |
03-24-2015, 07:45 | #7 (permalink) |
Member: 1323797 Status: Offline Thanks Meter: 154 | ok let me tell you somthing sir.the file wich i have that is you are the one who is uploaded some where in this forum so my question is can i use that file or i can read from working phone? |
03-24-2015, 07:50 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | If you have totally dead phone, use method i described. If phone power on but hang, then you can flash any rom. You can also make standard firmware for spft from working phone. Google it "how to make flash tool firmware with mtk droid tools" B.r. Alex |
The Following User Says Thank You to Brka For This Useful Post: |
03-25-2015, 07:08 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | Use some other spft from my posts, v3.1444, Format the phone, if it pass, use tesrpoint merhod, Write rom_0 file and it will be alive. If same errros, Then its not a software problem. The end. |
03-25-2015, 07:23 | #11 (permalink) |
Member: 1323797 Status: Offline Thanks Meter: 154 | ok i will do it.thanks for help so much sir.but even when i try to upgrade with upgrade software its says YOU SELECT A WRONG MODEL NAME......and this phone was ok condition i was just try to learn how to flash this phone with sp tool but by some mistake its hang on logo now.so its 100% software problem sir.sir if u feel free can u plz check on team viwer.thanks for help me alot sir. |
03-25-2015, 07:48 | #12 (permalink) |
Member: 1323797 Status: Offline Thanks Meter: 154 | i configure out a problem and i think thats the problem so thats how i cant flash my phone with sp tool.lets just see ii plz. i thing those files are there but thy dont have the path.so plz tell me what should i do.coz when i deselct these files than other files are flash done normaly to phone without any problem. |
03-25-2015, 15:09 | #13 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | First of all, you have wrong scatter file, rename it to MT6575_Android_Scatter_emmc.txt Second, when you tick some files, you need to click/double click that row, and open file dialog will open, to select file from folder. Third, if after all or that it still reports error, you probably formatted phone, And will need to use testpoint to flash preloader and dsp_bl After that, flash phone normally. B.r Alex |
03-27-2015, 05:55 | #14 (permalink) |
Member: 1323797 Status: Offline Thanks Meter: 154 | now iam at stage of upgrade with mobile upgrade software.so when i flash with PRO_INFO file wich you post on other thread mobile upgrade software says dont have upgraded file its already upgrade so than i edit PRO_INFO file but after edit and write to the phone when i try to upgrad mobile upgrade software says you select wrong name or model etc etc.so plz explain me how to edit pid correctly coz i know iam doing somthing wrong thats how i cant edit pid correctly.thanks in advance. |
