Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
11-10-2018, 16:31 | #1 (permalink) |
Junior Member Join Date: Jul 2017 Location: Colombia
Member: 2735235 Status: Offline Thanks Meter: 10 | repair imei alcatel 5059A UNSUCCESSFULLY |
11-10-2018, 20:46 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | All information is on the forum, all you need to do is use SEARCH button. First and strange thing is - HOW did it lost it's imei, when alcatel/tcl models have OTP imei programmed into flash memory ic, which always restore, even after full device wipe even via box ? If you by some means under "repair" mean "change" imei ... that is a no-go way. That wont be possible. Some of quick ideas comes to mind - by simple reading security backup from working phone and writing to that one via commercial box, and after that full factory reset - imei should be back to original state. there are factory APDB+BPLGUI files, but since it's not "user-bootable" device (you can't simply use MauiMeta, because device has multiple boot authentications), we can consider it as not user-possible. One more possible way is - by using factory device updater, which can be downloaded via this link : Mobile_Upgrade_S_Gotu2_v5.3.5 (install, select id drop-down list model 5059 and follow instructions) If it will be able to restore it - imei will be also back. Take a try ... something must work. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
