Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
10-17-2015, 20:10 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
So I got full repair ROM_0 backup from that model, download - HERE Attached is scatter file, and preloader, which is needed for flashing, and you need also SPFlashTools - download HERE - Download and unpack all, and put unpacked scatter+preloader into ROM_0 unpacked folder - Start SPFT, scatter-loading, load scatter file from rom_0 folder - Go to drop-down menu "Window", select "Write Memory", new tab appears - Go to new tab, "Open Raw Data", open ROM_0 File, Select under "Memory setting" EMMC - Begin address : 0x0000000000000000 , Container Length : 0x77500000 - Press "Write memory", connect powered off phone to cable, wait to finish - After done, reconnect battery, check if phone power on - If not, return to "Download" Tab, and flash just preloader - Check if power on, and enter Recovery mode if so - From recovery, do Wipe Data / Cache , then reboot - Wait for first start, it takes longer time to boot. try and post results. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
10-18-2015, 22:24 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Try full format from spflashtool first, after write preloader, And after write rom_0 B.r Alex
10-19-2015, 23:02 | #5 (permalink) |
Freak Poster Join Date: Jun 2007 Location: azores
Member: 523989 Status: Offline Thanks Meter: 2 | he just FlashTool sign that I am connecting to the PC but it does not appear anything or the recovery from the, please help me I do not know how to put the flash in it so simply sign on pc but not start nothing |
04-07-2016, 03:50 | #9 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Open your eyes, and use SEARCH before posting. Now, read thread from beginning. b.r. Alex.
06-27-2016, 20:54 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Stock 4013D (same as vf695) - HERE Video guide how to flash - HERE Custom Recovery for 4013D/v695 - HERE Custom Recovery ROM's : - Wiko Sunset ROM for 4013d/v695 - HERE - Stock Russian 4013D - HERE Imei FIX image for custom recovery - HERE p.s. for custom recovery, download some of first 2 rom's, and use scatter from it, manually load recovery.img. also, read full thread from beginning. b.r. Alex
06-28-2016, 17:46 | #13 (permalink) | |
No Life Poster Join Date: Jan 2007
Member: 432765 Status: Offline Thanks Meter: 65 | Quote:
phone coming freez in logo rom flash done phone not powered on i can't flash preloader ' PMT CHANGED ...... ERROR SP FLASH TOOL i change many flash tool still same i format phone but still same can't write peloader need help | |
06-28-2016, 22:03 | #14 (permalink) | |
b.r. Alex
