Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 10-16-2015, 23:16   #1 (permalink)
Member: 523989
Thanks Meter: 2
need vf695 flash file
hi plz i need vf695 flash file like scater i flash with wrong file and phone is dead now help plz
Old 10-17-2015, 20:10   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,778
Phone is identical to OT-4013D (Pixi 3 4"),
So I got full repair ROM_0 backup from that model, download - HERE
Attached is scatter file, and preloader, which is needed for flashing,
and you need also SPFlashTools - download HERE
- Download and unpack all, and put unpacked scatter+preloader into ROM_0 unpacked folder
- Start SPFT, scatter-loading, load scatter file from rom_0 folder
- Go to drop-down menu "Window", select "Write Memory", new tab appears
- Go to new tab, "Open Raw Data", open ROM_0 File, Select under "Memory setting" EMMC
- Begin address : 0x0000000000000000 , Container Length : 0x77500000
- Press "Write memory", connect powered off phone to cable, wait to finish
- After done, reconnect battery, check if phone power on
- If not, return to "Download" Tab, and flash just preloader
- Check if power on, and enter Recovery mode if so
- From recovery, do Wipe Data / Cache , then reboot
- Wait for first start, it takes longer time to boot.
try and post results.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 10-18-2015, 22:01   #3 (permalink)
Member: 523989
Thanks Meter: 2
no work
brom error:s_not_enough_storage_space-1011
Old 10-18-2015, 22:24   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,778
Try full format from spflashtool first, after write preloader,
And after write rom_0
B.r
Alex
__________________
Old 10-19-2015, 23:02   #5 (permalink)
Member: 523989
Thanks Meter: 2
he just FlashTool sign that I am connecting to the PC but it does not appear anything or the recovery from the, please help me I do not know how to put the flash in it so simply sign on pc but not start nothing
Old 11-08-2015, 15:12   #6 (permalink)
Member: 523989
Thanks Meter: 2
Alcatel Vodafone VF695 is dead after format
PLEASE HELP ME THIS FONE NO WORK AFTER FORMAT
only signal on the PC but no longer does anything please help me
Old 03-18-2016, 21:43   #7 (permalink)
Member: 1374018
Sonork: kelvin999
it works for me
b.r.
Old 04-06-2016, 23:02   #8 (permalink)
toni_85's Avatar
Member: 2070856
Thanks Meter: 62
I need vodafone 695 firmware anyone can uploud it please
Sent from my iPhone using Tapatalk
Old 04-07-2016, 03:50   #9 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,778
Open your eyes, and use SEARCH before posting.
Now, read thread from beginning.
b.r.
Alex.
__________________
Old 04-07-2016, 21:45   #10 (permalink)
toni_85's Avatar
Member: 2070856
Thanks Meter: 62
b.r.
Alex.
I was a bit cofuse bro didnt see it, later on i saw and i worked thanx for your post
Old 06-27-2016, 16:25   #11 (permalink)
ashaka's Avatar
Member: 617840
Thanks Meter: 49
Vodafone smart first 6 , v695-2AVDGB2. NEED ROM
dead after format need rom
Old 06-27-2016, 20:54   #12 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,778
Stock 4013D (same as vf695) - HERE
Video guide how to flash - HERE
Custom Recovery for 4013D/v695 - HERE
Custom Recovery ROM's :
- Wiko Sunset ROM for 4013d/v695 - HERE
- Stock Russian 4013D - HERE
Imei FIX image for custom recovery - HERE
p.s. for custom recovery, download some of first 2 rom's, and use scatter from it,
manually load recovery.img.
also, read full thread from beginning.
b.r.
Alex
__________________
Old 06-28-2016, 17:46   #13 (permalink)
Member: 432765
Thanks Meter: 65
b.r.
Alex
hello
phone coming freez in logo
rom flash done
phone not powered on
i can't flash preloader ' PMT CHANGED ...... ERROR SP FLASH TOOL
i change many flash tool still same
i format phone but still same can't write peloader
need help
Old 06-28-2016, 22:03   #14 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,778
Originally Posted by fessi View Post
hello
rom flash done
need help
Have you tried post #2 ? If not, try and post results.
b.r.
Alex
__________________
Old 06-29-2016, 11:06   #15 (permalink)
Member: 432765
Thanks Meter: 65
b.r.
Alex
hello thinks for reply
but still same
Page generated in 0.30695 seconds with 9 queries
