ALCATEL POP 3 5015D FRP Reset DONE I've found a new way on Alcatel Pop 3 5015D. Nothing else works with the latest firmware update. Cheers 1.You should be connected to wi-fi 2.Click on enter you email and long press the "@" 3.Click on settings icon 4.Click "Android Keyboard Settings" 5.Click Languages 6.Turn off "Use system language" 7.Enable English and one more language from the list 8.Go back 9.Click "Text correction" 10.Click "Personal dictionary" 11.Click "For all languages" 12.Click on the search symbol 13.Long press on the space bar of the keyboard and select "Multiple Languages/SwiftKey Keyboard" 14.Click on the three short lines (sign for settings) in the left corner of the SwiftKey Keayboard 15.Click "More" 16.Click "About SwiftKey" 17.Click on the "swiftkey.com" 18.Select Internet Browser Now just search for the "quickshortcutmaker" apk and install it. When installed in the search bar type Setting and open it. Now enable developer mode and inside enable OEM unlock and USB debugging. Go back and just click Backup and Restore. Inside uncheck Auto Restore and reset the phone. That is it Click Thanks :) |
New alcatel FRP remove (tutorial) Remove frp from new alcatel phones (android 5 and 6) : 1.- Go in recovery mode and activate adb ( last line in recovery "enable adb") and reboot phone 2.- Connect phone to usb and open adb shell and enter this commands adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1 adb shell am start -S com.android.settings/.Settings 3.- Settings are opened and go to accounts and add your gmail account (one that you are using and know password) 4.- Reboot phone ( power off button) 5.- When reboot is done, phone start normal 6.- Go to settings and account and remove gmail account from menu then go to back up & reset and factory reset your phone. Your phone is OK. THX to my russian frend EG67. |
my alcatel 6055y dont have enable adb option |
my TCL 5056 with 6.0 does not have that option in recovery mode |
ADB enable not a option on the Idol model either. |
Alcatel Flint 5054 FRP Bypass 1000% Solución Cuenta Google hello bros. this is my solution.. good luck |
One touch alcatel frp lock 1 ▶️ Power on your smart phone which have FRP locked 2 ▶️ once your Mobile Phone power on start the process connects Wifi 3 ▶️ Press Next you will see Google which is need Google account id 4 ▶️ in this page you just select create Account once you select first name your Keypad will appear Press from keypad voice sign and then select Google 5 ▶️ here will be two options you just select Settings 6 ▶️ once you press setting you will see Question Mark sign press it Then you will see help page In here you just press more options sign and select “View in Google Play Store” Open Google here 6 ▶️ Search setting in Google setting will appears 7 ▶️ this setting will be your phone setting here just press Backup and Restore 8 ▶️ Make factory reset your phone will be factory reset and your google account id Be remove and wait until your will reset and Enjoy. |
Alcatel 5049W T-Mobile REVVL FRP bypass 7.0 Alcatel 5049W T-Mobile REVVL FRP bypass 7.0 |
these phone only methods no longer work |
Alcatel Verso FRP bypass | Alcatel 5044C FRP/Google bypass | Alcatel Cricket Wirelss FRP 2018 This video is for Alcatel Verso/5044C Android 7.0 FRP/Google account removal. It do not requires a Computer / USB Cable or any Commercial Box. All just via phone's WIFI.... |
Alcatel PulseMix FRP/Google account bypass | Alcatel 5085C Cricket FRP/Google ID bypass 100% Working How to bypass Google account from Alcatel PulseMix aka 5085C Cricket. With Android 7.0 This don't requires any commercial box/device/Computer. All you need is WIFI :) FRP bypass method is super easy, I think anyone can do this.... Alcatel 5085C FRP bypass Alcatel PulseMix FRP bypass Alcatel PulseMix Google ID bypass Alcatel 5085C Google ID bypass Alcatel FRP Unlock Alcatel FRP bypass Android 7.0 |
Alcatel U5 HD/5047U.Remove google account,Bypass FRP.Without PC!!! Download and copy to SDcard:****************************/file/iaomi...nlock.apk/file |
Alcatel 5026D,Remove Google Account,Bypass FRP.Without PC. Download and copy this file to sdcard and insert on frp locked phone:****************************/file/iaomi...nlock.apk/file |
Alcatel 5052D Frp lock help me CPU: MT6739 Andoid 8.1 Oreo |
Alcatel 5059l FRP Bypass Done Model: Alcatel 5059l Android Version: 8.1.0 Security Patch: 5 June 2018 Basaeband Version: MT6739WA Remove FRP Lock By enable ABD from Recovery. just follow my steps and you will get it... 1. Power off your device. 2. Inter Recovery Mode (Press Vol+ and Power Button. after vibrate your phone then release power and keep press vol+). 3. Press Enable_ABD. 4. Remove FRP via adb (no box needed - copy/paste line by line followed by enter) : Quote:
6. Finished and Enjoy.:p Here is some picture's for you... https://uploads.tapatalk-cdn.com/201...2f9b1ce61e.jpg https://uploads.tapatalk-cdn.com/201...283534aade.jpg |
