Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
12-23-2014, 02:24 | #1 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | Alcatel 7041D ROM Needed (Phone dead after flash) Last edited by Brka; 11-10-2017 at 21:03. Reason: removed boxes |
12-23-2014, 20:01 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
- use some newer SPFlashTools - like v5.1420.00 - download HERE - flash from ot-7041x without system + custpack - download HERE start SPFlashTools, go to Scatter-Loading, select scatter file, form folder where you unpacked downloaded flash file(s) first try with this scatter - MT6582_Android_scatter_7041_revive if doesn't power on, try other one - MT6582_Android_scatter_7041_revive_patched_boot flash the phone, I hope it will start powering on after. attached files doesn't have system+custpack, you can flash them separately, from downloaded flash files from support, via attached flasher, just load scatter file from that folder (rename it from .sca to .txt), and de-select files other than system and custpack. this is important, because android system from 7041D model, will work with BOTH sim cards, and system from 7041X is single-sim. in any of those cases ... after any operation, you can try to use factory updater which in 99% cases get phone back to life download Alcatel OTU - HERE (as long as sensitive data from phone is there) try and post results. b.r. Alex Last edited by Brka; 11-10-2017 at 21:04. Reason: removed boxes | |
12-24-2014, 20:47 | #3 (permalink) |
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | thanks sir for yyour interestt, i cant solve myy problem yet, same at box : Flash files count is :13 Action : Firmware update. Selected Alcatel: Vid_0e8d&Pid_0003 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM18) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6582_S00 EMMC: (28Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 86:00:00:00:00:00:00:00 BOOT STYLE : EMMC BOOT Starting flash. Error: S_NOT_ENOUGH_STORAGE_SPACE Wait untill phone will start charging. All done. Last edited by Brka; 11-10-2017 at 21:05. Reason: removed boxes |
12-27-2014, 16:52 | #4 (permalink) |
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | i dond know hhow to flash this rom 7041x_FULL_BACKUP_ROM_0_unlocked i tried with ******** box but stuck and cant flash,its bin file so i cant flashh with sp flash tool thanks for your interest please help me... Last edited by Brka; 02-04-2017 at 22:46. Reason: removed boxes |
12-27-2014, 17:09 | #5 (permalink) | |
It have tab "write memory", open scatter file, then select rom_0 file, Press write, connect phone.... Post results B.r. Alex Last edited by Brka; 02-04-2017 at 22:46. Reason: removed box | |
The Following User Says Thank You to Brka For This Useful Post: |
12-27-2014, 18:06 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Select emmc under memory settings and retry flashing b.r. Alex Last edited by Brka; 12-27-2014 at 18:58. |
12-28-2014, 21:08 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | now, this looks like other issue, since your phone is erased fully, you will need to connect it in another way, like I already described somewhere, I dunno ecactly which key combination, but you can try some of these : - both volume keys + power on + connect cable - volume up + power on + connect cable - volume down + power on + connect cable you will know if you connected it right, PC will start installing new drivers, that's "dead/erased mode - aka. as old testpoint mode". now, after installing drivers - which will appear in dev. manager, as MTK USB VCOM port (com XX), you should retry flashing the phone. sometimes, I noticed, I had problems with some errors in SPFT, under one windows, and since I have several Windows, (Win7, XP), after rebooting to another one, it all started working, so you can consider your pc / windows being another problem. solution is - trying on another pc/windows, of course. and, I still think that your phone is not brick, and that it can be repaired .... you just need to keep trying. p.s. can you share here, your original PID ? 7041D-XXXXXXX I want to check available flashes ... b.r. Alex |
12-29-2014, 16:10 | #12 (permalink) | |
This is the firmware, that OTU updater updates for that pid. Try with different SPFlashTools ... and post results. b.r. Alex | |
12-30-2014, 16:08 | #13 (permalink) |
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | only preloader now i can flash with this rom, i tried on another sptool-nck box same error when i try to flash phone still dead thanks for your interest.... |
12-30-2014, 18:03 | #14 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | first of all, now you can try to do full flash format from spft after, to flash only preloader file, and after, flash same flash with all selected, try also "firmware upgrade" option in SPFT. for flashing preloader ... try volume down + power before connect to PC, to flash preloader. after it's done, hold power button ~10 seconds, it should restart into another mode (for normal flash write, not emergency (preloader)) also, try with other SPFT, SP-Flash-Tool-v3.1344.0.212 if still unsuccessful, go to memory testing option, and do memory tests, post screenshot, maybe it's eMMC problem ... b.r. Alex Last edited by Brka; 12-30-2014 at 18:10. |
12-31-2014, 08:38 | #15 (permalink) | |
Freak Poster Join Date: Jan 2006
Member: 223499 Status: Offline Thanks Meter: 46 | Quote:
Code: ============ Memory Detection Report =========== Internal RAM: Size = 0x00020000 (128KB) External RAM: Type = DRAM Size = 0x20000000 (0MB/512Mb) NAND Flash: ERROR: NAND Flash was not detected! EMMC: EMMC_PART_BOOT1 Size = 0x0000000000200000(0MB) EMMC_PART_BOOT2 Size = 0x0000000000000002(0MB) EMMC_PART_RPMB Size = 0x0000000000200000(0MB) EMMC_PART_GP1 Size = 0x0000000000000002(0MB) EMMC_PART_GP2 Size = 0x0000000000200000(0MB) EMMC_PART_GP3 Size = 0x0000000000000002(0MB) EMMC_PART_GP4 Size = 0x0000000000000000(0MB) EMMC_PART_USER Size = 0x0000000000000000(0MB) ============ RAM Test ============ Data Bus Test: [D0] [D1] [D2] [D3] [D4] [D5] [D6] [D7] [D8] [D9] [D10] [D11] [D12] [D13] [D14] [D15] [D16] [D17] [D18] [D19] [D20] [D21] [D22] [D23] [D24] [D25] [D26] [D27] [D28] [D29] [D30] [D31] OK!! Address Bus Test: [A1] [A2] [A3] [A4] [A5] [A6] [A7] [A8] [A9] [A10] [A11] [A12] [A13] [A14] [A15] [A16] [A17] [A18] [A19] [A20] [A21] [A22] [A23] [A24] [A25] [A26] [A27] [A28] OK!! Writing ... Last edited by Brka; 12-31-2014 at 19:50. Reason: added code tag for better visibility | |
