Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 12-31-2014, 09:57   #16 (permalink)
Registered User
Member: 1725884
Sonork: swimming
Thanks Meter: 293
Old 12-31-2014, 12:52   #17 (permalink)
Registered User
Member: 1725884
Sonork: swimming
Thanks Meter: 293
=============== Memory Detection Report ===============
Internal RAM:
Size = 0x00020000 (128KB)
External RAM:
Type = DRAM
Size = 0x20000000 (512MB/4096Mb)
NAND Flash:
ERROR: NAND Flash was not detected!
EMMC :
EMMC_PART_BOOT1 Size = 0x0000000000200000(2MB)
EMMC_PART_BOOT2 Size = 0x0000000000200000(2MB)
EMMC_PART_RPMB Size = 0x0000000000200000(2MB)
EMMC_PART_GP1 Size = 0x0000000000000000(0MB)
EMMC_PART_GP2 Size = 0x0000000000000000(0MB)
EMMC_PART_GP3 Size = 0x0000000000000000(0MB)
EMMC_PART_GP4 Size = 0x0000000000000000(0MB)
EMMC_PART_USER Size = 0x00000000E7000000(3696MB)
============ RAM Test ============
Data Bus Test :
[D0][D1][D2][D3][D4][D5][D6][D7][D8][D9][D10][D11][D12][D13][D14][D15][D16][D17][D18][D19][D20][D21][D22][D23][D24][D25][D26][D27][D28][D29][D30][D31]
OK!!
Address Bus Test :
[A1][A2][A3][A4][A5][A6][A7][A8][A9][A10][A11][A12][A13][A14][A15][A16][A17][A18][A19][A20][A21][A22][A23][A24][A25][A26][A27][A28]
OK!!
RAM Pattern Test :
Writing ...
0x44332211,
0xA5A5A5A5,
Old 12-31-2014, 19:52   #18 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Originally Posted by hochoi View Post
me same prolem log test
Internal RAM:
External RAM:
	Type = DRAM
	Size = 0x20000000 (0MB/512Mb)
NAND Flash:
EMMC:
	 EMMC_PART_BOOT1 	Size = 0x0000000000200000(0MB)
	 EMMC_PART_BOOT2 	Size = 0x0000000000000002(0MB)
	 EMMC_PART_RPMB 	Size = 0x0000000000200000(0MB)
	 EMMC_PART_GP1 	Size = 0x0000000000000002(0MB)
	 EMMC_PART_GP2 	Size = 0x0000000000200000(0MB)
	 EMMC_PART_GP3 	Size = 0x0000000000000002(0MB)
	 EMMC_PART_USER 	Size = 0x0000000000000000(0MB)
Data Bus Test:
[D0]
[D1]
[D2]
[D3]
[D4]
[D5]
[D6]
[D7]
[D8]
[D9]
[D10]
[D11]
[D12]
[D13]
[D14]
[D15]
[D16]
[D17]
[D18]
[D19]
[D20]
[D21]
[D22]
[D23]
[D24]
[D25]
[D26]
[D27]
[D28]
[D29]
[D30]
[D31]
OK!!
Address Bus Test:
[A1]
[A2]
[A3]
[A4]
[A5]
[A6]
[A7]
[A8]
[A9]
[A10]
[A11]
[A12]
[A13]
[A14]
[A15]
[A16]
[A17]
[A18]
[A19]
[A20]
[A21]
[A22]
[A23]
[A24]
[A25]
[A26]
[A27]
[A28]
OK!!
RAM Pattern Test :
Writing ...
Looks like phone hardware is totally functional.
however, phone doesn't have partitions.
preloader, ebr1, ebr2, mbr, needs to be flashed first.
or all at once.
if it doesn't want to flash, maybe full flash from other same phone can help.
if that also doesn't help ....
last thing to do, that is left, is trying to write preloader,
edited pro_info, and try to update it via OTU updater.
read sticky threads how to do it.
b.r.
Alex
The Following User Says Thank You to Brka For This Useful Post:
Old 12-31-2014, 20:08   #19 (permalink)
Registered User
Member: 1725884
Sonork: swimming
Thanks Meter: 293
and for me what do you think i can do now, thanks for your interest....
Old 01-01-2015, 00:43   #20 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
first, avoid using 5.x version of SPFlashTool,
second, did you make "format all" or "format all except preloader" ? (from SPFlashTools)
third, last flash file I uploaded, exactly for your phone,
doesn't have few partitions, like pro_info, nvram,
(however, phone should power on without them).
you can combine it from 7041x flash I posted earlier,
put them in same folder with 7041D flash,
edit scatter file (where is __NODL_NVRAM , __NODL_PRO_INFO, remove "__NODL_",
and manually click/load missing 2 partitions.
error that you were getting earlier, is usually happening,
when flash file is not intended for that phone type,
so maybe it's time to re-check your PID, model, etc.
also, finding one exactly the same, working phone, would help a lot,
it can be read full backup, and try to write into non-working,
or make SPFlashTools flashes from that same full backup.
I don't exactly know, maybe there is some hardware difference,
but that's hardly possible, last flash I posted is for your phone, 100%.
as I said ... at the end, do FULL FORMAT, after - write preloader,
and edited pro_info (edit model into 7041D-your_pid ),
try to flash full flash, or try with OTU.
b.r.
Alex
Old 01-04-2015, 13:19   #21 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
@Brka
This user contacted me and sayed phone ask for password, not stuck on logo as i'am read now here.
And wipe not work.
I'am provided usrdata and cache and after he flashed this sayed, phone become dead.
Usually after flashing this 2 partitions or make format from recovery phone must power on.
Now...here can be 2 problems.
1.Phone is not OT-7041D
2.Phone have some hardware problems.
I'am spended also some time with this user and also without succes.
__NODL_PRO_INFO is not important in alcatels.
This file is used only by updater, and can be formated without problem.
Phone will work ok after.
__NODL_NVRAM in alcatel will be remaked on first startup.
Factory flasher simple erase this region on flashing.
Worst case is damaged imei, but phone will start.
The Following 2 Users Say Thank You to orbita For This Useful Post:
Old 01-04-2015, 20:50   #22 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Originally Posted by orbita View Post
@Brka
And wipe not work.
Yes bro, I know ... I tried to help, but this is totally strange for me too.
If you checked, I found original flashes for that model, but it still refuses to flash.
And, in the middle of all that - it accepts preloader (!?!)
I had in my hands one 7041x (which is identical hardware except one less sim slot),
and I played with it, full format, partial format, and many other things,
but I always got it back to life, either with full backup or important partitions.
Now ... that phone comes in few different flavours :
Single SIM: 7040A, 7040F, 7041X
Dual SIM: 7040D, 7041D, 7040E
is it possible somehow that they will not allow crossflash,
and that his phone is not the model he wrote ?
of course, I totally agree, since the phone came stuck on boot,
that eMMC chip is dead, that is always one of possibilities.
for example, I repaired couple of 4010x and 5020x models,
which acted similar, with simple reheating emmc chip,
even flashing was not needed, just hot air soldering gun.
b.r.
Alex
Old 01-04-2015, 21:09   #23 (permalink)
Registered User
Member: 1725884
Sonork: swimming
Thanks Meter: 293
thanks for all, but mr orbita i didnt tell that phone has password but phone came to hang on logo and iam still waiting for help because iam ********* box user and mr brka thank you for your help, phone still dead need help....
Old 01-04-2015, 23:18   #24 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
From what we maked online and what you maked here with Brka help, it's 99.99% posibility to be hardware damage.
What help exactly you expect?
What i'am can sugest, disasemble phone and inspect for water damage.
Also rehot or better reball CPU and flash IC.
The Following User Says Thank You to orbita For This Useful Post:
Old 01-06-2015, 16:02   #25 (permalink)
Registered User
Member: 1725884
Sonork: swimming
Thanks Meter: 293
thanks for all i think thread should closed because its hardware as mr orbita and mr brka told me thanks for help but iam only work in sotware...
Old 07-09-2015, 13:41   #26 (permalink)
Member: 2039241
Thanks Meter: 5
how to repair alcatel 7041d emmc?
Old 09-28-2015, 06:31   #27 (permalink)
Member: 2013701
Thanks Meter: 24
hello my friend i have to same problem how to repair my phone is fully deadd
Old 09-28-2015, 14:20   #28 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
You cant.
Just board swap/exchange.
B.r
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 12-07-2015, 05:09   #29 (permalink)
kjava's Avatar
Member: 846616
Sonork: 100.1675590
Thanks Meter: 581
Originally Posted by Brka View Post
Now ... here's something for you .... ORIGINAL Flash file, for 7041D-2BALEG1 - HERE
This is the firmware, that OTU updater updates for that pid.
Try with different SPFlashTools ... and post results.
b.r.
Alex
I just confirm that flash is safe for update but u must choose firmware update than press download
Old 12-07-2015, 05:33   #30 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Every flash i posted is "safe" because it's original stock firmware,
Problem is, as i already wrote, with buggy cpu+emmc combination,
So, flashing preloader on those models is pure gambling,
It may lead to bricked phone, or in other hand - not.
All is up to user's decisions.
Again, and for the last time - safest way is via pro_info method + otu.
B.r.
Alex
__________________
Page generated in 0.28044 seconds with 9 queries
