Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
12-16-2014, 23:45 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Okay, Virtually, it's same phone as normal ot-985, just IDEA branded. First thing to try, as usually, is factory upgrade tool for 985 model, you can download it HERE, it will also install drivers, needed for it, and eventually, other reviving method. if that works for you - great, you don't have to read further. If not .... Since you didn't wrote whats the real problem with your phone, I assume that phone can power on, and you want to bring it back to life. It will NOT have IDEA branding and other stuff after this, but it will work. Steps to do that : - Download CWM Recovery HERE - Download custom rom 1 - HERE "ot985 Dark Ginger" or - Download custom rom 2 - HERE "ot985 CyanogenMod 7" or - Download custom rom 3 - HERE "ot985 Xperia Mod" now ... unpack CWM, power off the phone ; Start SPFlashTools, from right panel, "scatter loading" - select file from folder "cwm", it will report some errors, its ok, just press ok, and again. Press button "Download", connect powered off phone to cable, it should stard working, and after finished, it will display green circle, means it's done. now, put any of desired custom roms to SDCard, and insert in phone, and hold VOLUME UP button, and while holding, press power on for 3-5 seconds. after some time, you will be in CWM recovery. option "install zip from sdcard", select .zip file you put earlier on it (rom must be .zip extension, check if rom you downloaded is unpacked from .rar or .7z) After that, go back and do reboot system. that's it, wait for phone to power up. and ... post results. b.r. Alex |
12-20-2014, 20:29 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote: If you have more regional flashes for those Alcatel IDEA branded models, please share. (Aurus III, etc.) b.r. Alex | |
12-29-2014, 15:55 | #5 (permalink) | |
I found ORIGINAL firmware for your phone, for that PID (985n-2dijin1) - download HERE test it and post results. b.r. Alex | |
01-17-2015, 15:34 | #6 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
this is also not work in your file 56% failed in flash | |
01-17-2015, 18:05 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | All fine with files, you have some other problem. (files are from alcatel service site) either try same files with some commercial box, or read sticky thread, and edit pro_info , flash to phone, and use official updater (OTU). b.r. ALex |
01-19-2015, 15:45 | #9 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | You can also post here full procedure, what you did, it can be helpful to other users. Also, edited pro_info file, rar/zip it and attach here, so i can add it To sticky thread. Thanx B.r. Alex |
The Following User Says Thank You to Brka For This Useful Post: |
