Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 03-24-2015, 17:42   #1 (permalink)
xx0o0xx1's Avatar
Member: 2033150
Thanks Meter: 624
ONE TOUCH TAB 7 DUAL CORE firmware
hi all
plz can any one helping me to find ONE TOUCH TAB 7 DUAL CORE firmware
it's urgent
ALCATEL ONETOUCH - Products - Tablets - ONE TOUCH TAB 7 DUAL CORE
The Following 2 Users Say Thank You to xx0o0xx1 For This Useful Post:
Old 03-24-2015, 23:33   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by xx0o0xx1 View Post
hi all
it's urgent
Hi,
You cant flash that tablet easily, there is no OTU updater for that model.
b.r.
Alex
Old 03-26-2015, 18:20   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
so ..what should i do ?
try to find sticker on tablet, like on attached example,
and take a picture of it, it will reveal some important information
attach picture here
b.r.
Alex
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 03-26-2015, 18:26   #4 (permalink)
xx0o0xx1's Avatar
Member: 2033150
Thanks Meter: 624
There is no sticker... But there's word wrote on the back cover
Model netouch tab 7 dual core
Tct mobile limited
Board id : 8470c v2.0
Aml8726_mxs dual core
Thats all
Old 03-27-2015, 22:49   #5 (permalink)
Member: 2369718
Thanks Meter: 5
here is data from my sticker
GAJIRBD00000222
pth 1.0
pts 100
forgot to mention
same logic board ID
please report do you need any numbers for this tablet?
here a 80% workin rom for alcatel one touch folow the procedure from this page and you will rescue your tab, google
855-kak-vosstanovit-planshet-prestigio-multipad-pmp3970b-7-0-hd-duo
but wi fi and g sensor wont work ((
a update dowload and install via SD card method firmware for prestigio 3970B
and g sensor work
wi fistill not chip inside tab7 is realtek8188
in prestigio wifi chip is realtek8188eus and inside tab7 realtek8188etv
The Following User Says Thank You to grunftz For This Useful Post:
Old 03-30-2015, 12:34   #6 (permalink)
Member: 2371037
Thanks Meter: 3
attach picture here
b.r.
Alex
Hello Alex, Here is the sticker of the Alcatel One Touch tab 7 dual core. I need help also to unbrick my tablet. I hope this helps. It says the serial number GAJOSBD0000074F. PTH 1.0, PTS 103. CU REF: T015-3AC2PH1
The Following 3 Users Say Thank You to Johnny009 For This Useful Post:
Old 03-30-2015, 16:34   #7 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Okay so, mystery solved - its T015
EDIT: Looks like 2 different sub-versions exists T015 and T017
checking software compatibility ... not the same.
Unbricking works fine, even hard-brick (not detected by pc) works.
p.s. Flashing not going regular way, so don't ask for flashfiles.
Tab needs to be brought to someone with service access
or regular alcatel service point.
b.r.
Alex
The Following 14 Users Say Thank You to Brka For This Useful Post:
Old 03-31-2015, 02:08   #8 (permalink)
Member: 2371037
Thanks Meter: 3
Yeah, the thanks button help alot. Folks, please don't forget to click the "Thank you" button or link located on the lower right corner. How is it going with the test of yours, Alex?
Old 04-01-2015, 12:08   #9 (permalink)
Member: 2371037
Thanks Meter: 3
Mine is soft bricked, it still shows the splash screen ALCATEL ONE TOUCH then nothing happens.
Old 04-01-2015, 17:20   #10 (permalink)
Member: 2369718
Thanks Meter: 5
mine was hard bricked, so had to short circuit those two pins from first picture to get recognize by PC...menage to install TWRP, but cant root, yet and still trying ...
Old 04-09-2015, 04:12   #11 (permalink)
Member: 2299829
I have the T017 model, can you tell me where you get the firmware for the T015, since it's specified that it's not compatible, maybe there's a different firmware fot the T017 model.
Here's my back sticker
postimg org / image / pme238511/
Sorry, I can't use links yet
Old 04-15-2015, 08:22   #12 (permalink)
Member: 2374721
Hi grunftz,
Thanks a lot, I follow your procedure and the tablet lit up while I was flashing it with amlogic burning tool. I am happy it was showing some signs of life but it failed at 33% without success, I tried to flash it again with pc and sd card but it won't boot. Did I missed something? Help is very much appreciated.
Old 04-15-2015, 09:14   #13 (permalink)
Member: 2369718
Thanks Meter: 5
ok find this on google
it will boot but g sensor and wifi wont work
than follow the standard procedure with T015 firmware
Old 04-16-2015, 12:40   #14 (permalink)
Member: 2374721
I try to find that on google but I found a few sites in Russian Language and it won't let me download. Anyway, I downloaded the PMP3970B duo firmware on another site and flash it using amlogic burning tool, it reached 78% then I try to flash it with sd card with firmware file but still won't boot.
Another thing I tried again the procedure using config_progress_erase and try to change usb port and reached 100% success, but there's no reaction when I put sd card, only through amlogic burning tool that I get some progress but the tab is still not booting. I'm not ready to give up yet anymore suggestions? Thanks for the help
Old 04-17-2015, 07:36   #15 (permalink)
Member: 2369718
Thanks Meter: 5
when you erase nand with suceess, than you need to follow procedure for install T015 ROM it will boot for shure, hope now is clear, dont try to boot from SD card you wont suceed
Page generated in 0.20002 seconds with 10 queries
