Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
03-24-2015, 17:42 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | ONE TOUCH TAB 7 DUAL CORE firmware plz can any one helping me to find ONE TOUCH TAB 7 DUAL CORE firmware it's urgent ALCATEL ONETOUCH - Products - Tablets - ONE TOUCH TAB 7 DUAL CORE |
The Following 2 Users Say Thank You to xx0o0xx1 For This Useful Post: |
03-24-2015, 23:33 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
You cant flash that tablet easily, there is no OTU updater for that model. b.r. Alex | |
03-26-2015, 18:20 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | try to find sticker on tablet, like on attached example, and take a picture of it, it will reveal some important information attach picture here b.r. Alex |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
03-26-2015, 18:26 | #4 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | There is no sticker... But there's word wrote on the back cover Model netouch tab 7 dual core Tct mobile limited Board id : 8470c v2.0 Aml8726_mxs dual core Thats all |
03-27-2015, 22:49 | #5 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2369718 Status: Offline Thanks Meter: 5 | here is data from my sticker GAJIRBD00000222 pth 1.0 pts 100 forgot to mention same logic board ID Board id : 8470c v2.0 ml8726_mxs dual core please report do you need any numbers for this tablet? here a 80% workin rom for alcatel one touch folow the procedure from this page and you will rescue your tab, google 855-kak-vosstanovit-planshet-prestigio-multipad-pmp3970b-7-0-hd-duo but wi fi and g sensor wont work (( a update dowload and install via SD card method firmware for prestigio 3970B and g sensor work wi fistill not chip inside tab7 is realtek8188 in prestigio wifi chip is realtek8188eus and inside tab7 realtek8188etv Last edited by Brka; 03-28-2015 at 02:05. Reason: consolidate forum space |
The Following User Says Thank You to grunftz For This Useful Post: |
03-30-2015, 12:34 | #6 (permalink) |
Member: 2371037 Status: Offline Thanks Meter: 3 | Hello Alex, Here is the sticker of the Alcatel One Touch tab 7 dual core. I need help also to unbrick my tablet. I hope this helps. It says the serial number GAJOSBD0000074F. PTH 1.0, PTS 103. CU REF: T015-3AC2PH1 |
The Following 3 Users Say Thank You to Johnny009 For This Useful Post: |
03-30-2015, 16:34 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Okay so, mystery solved - its T015 EDIT: Looks like 2 different sub-versions exists T015 and T017 checking software compatibility ... not the same. Unbricking works fine, even hard-brick (not detected by pc) works. p.s. Flashing not going regular way, so don't ask for flashfiles. Tab needs to be brought to someone with service access or regular alcatel service point. b.r. Alex Last edited by Brka; 12-11-2015 at 20:50. Reason: added pictures / some info |
The Following 14 Users Say Thank You to Brka For This Useful Post: |
03-31-2015, 02:08 | #8 (permalink) |
Member: 2371037 Status: Offline Thanks Meter: 3 | Yeah, the thanks button help alot. Folks, please don't forget to click the "Thank you" button or link located on the lower right corner. How is it going with the test of yours, Alex? |
04-09-2015, 04:12 | #11 (permalink) |
Junior Member Join Date: Nov 2014 Location: LA
Member: 2299829 Status: Offline Thanks Meter: 1 | I have the T017 model, can you tell me where you get the firmware for the T015, since it's specified that it's not compatible, maybe there's a different firmware fot the T017 model. Here's my back sticker postimg org / image / pme238511/ Sorry, I can't use links yet |
04-15-2015, 08:22 | #12 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2374721 Status: Offline Thanks Meter: 0 | Hi grunftz, Thanks a lot, I follow your procedure and the tablet lit up while I was flashing it with amlogic burning tool. I am happy it was showing some signs of life but it failed at 33% without success, I tried to flash it again with pc and sd card but it won't boot. Did I missed something? Help is very much appreciated. |
04-15-2015, 09:14 | #13 (permalink) |
Member: 2369718 Status: Offline Thanks Meter: 5 | ok find this on google 855-kak-vosstanovit-planshet-prestigio-multipad-pmp3970b-7-0-hd-duo it will boot but g sensor and wifi wont work than follow the standard procedure with T015 firmware |
04-16-2015, 12:40 | #14 (permalink) |
Member: 2374721 Status: Offline Thanks Meter: 0 | I try to find that on google but I found a few sites in Russian Language and it won't let me download. Anyway, I downloaded the PMP3970B duo firmware on another site and flash it using amlogic burning tool, it reached 78% then I try to flash it with sd card with firmware file but still won't boot. Another thing I tried again the procedure using config_progress_erase and try to change usb port and reached 100% success, but there's no reaction when I put sd card, only through amlogic burning tool that I get some progress but the tab is still not booting. I'm not ready to give up yet anymore suggestions? Thanks for the help |
04-17-2015, 07:36 | #15 (permalink) |
Member: 2369718 Status: Offline Thanks Meter: 5 | when you erase nand with suceess, than you need to follow procedure for install T015 ROM it will boot for shure, hope now is clear, dont try to boot from SD card you wont suceed |
