Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 06-23-2017, 23:07   #31 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by lucian07 View Post
can you teach me how to format FRP? pls
Use attached scatter, load in SPFT, go to tab "Format",
select "Manual format", tick "Validation", input these addresses :
- start address : 0xa000000
- length : 0x800000
Press start (PLAY) button, connect powered off phone to cable,
wait for finish, enter recovery (volume up + power on),
make "wipe data / cache", then reboot.
FRP should be gone.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 06-27-2017, 14:34   #32 (permalink)
Member: 2687165
Thanks Meter: 3
hi
any chance to get retail firmware for orange rise 51(alcatel pixi 4.5.0 5045Y) Nneed to get rid branded orange firmware make my phone very slowly ,always say orange launcher stopped working ((
Old 06-27-2017, 21:20   #33 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
5045Y is model for specific regions, and mostly made for Operators (Customized).
Only one is on the list, non-customized, and that's 5045Y-2[X=A,B]ALGB1,
Retail 5045Y for United Kingdom.
However, hardware should be identical as 5045x (single-sim) model (is your phone single or dual-sim ?)
So, flashing system (and logo, if boot animation is with orange),
should re-make your phone into "normal" 5045X model.
I have Poland Retail (no branding) ROM, if you are interested in trying ...
b.r.
Alex
__________________
Old 06-28-2017, 13:57   #34 (permalink)
Member: 2687165
Thanks Meter: 3
yes my phone is single sim hardware are the same as 5045X only difference is mine have NFC
yes i could try poland rom for 5045y BUT NO IDEEA HOW TO FLASH (
Old 06-28-2017, 21:10   #35 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
It's very simple in fact ...
Download 5045X Poland rom - HERE
Download SPFlashTool - HERE
- Unpack files, you will have folder \ot-5045X-2XTBPL1_Original_SPFT_ROM_by_bRkA
- In that folder, there is subfolder \5045X-2XALPL1_System
- move file system.img to previous folder, overwriting existing one system.img
- start SPFlashTools, load scatter file
- Flash the phone (press start, connect powered off phone to cable).
If you want to be sure, not to kill the phone,
de-select preloader before start flashing.
b.r.
Alex
__________________
Old 06-29-2017, 16:49   #36 (permalink)
Member: 2687165
Thanks Meter: 3
Many thanks it worked now i have alcatel 5045X)after flash phone hangs on alcatel logo i remove battery and started again and phone its alive ur the best
i unchecked preloader and simlock and flashed in download only mode
The Following User Says Thank You to lucian07 For This Useful Post:
Old 06-30-2017, 13:45   #37 (permalink)
Member: 2687165
Thanks Meter: 3
can you kindly share UK Retail firmware,i can try see if works I presume caant receive OTA update now right?
my phone cant get update now since im changed firmware right?any way to get updates for 5045X ?
which scatter file should i use for frp format since i have poland rom now?
Old 07-07-2017, 22:04   #38 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Alcatel updates .. heh ... alcatel updates lasts max. 1 year from release data of phone,
so ... forget about updates, in any case.
scatter is the same as any before posted, for 5045 model,
or the one you last used.
b.r.
Alex
__________________
Old 07-10-2017, 15:37   #39 (permalink)
Member: 2687165
Thanks Meter: 3
hi
i mean security patch,with orange branded rom i receive update via OTA last is from march 2017
Old 09-28-2017, 21:57   #40 (permalink)
Member: 2762598
Hi. Orange rom help me to (after try flash official 5045X rom... ). I try Poland ROM too (my region ^^). I need to ask - it's any option to disable volume warnings? Ex. they popup every 3-5min and are annoying + stop every time netfilx :P
PS. Orange ROM lose sim card :/
PPS. Poland rom download are poor :/ orange download with full speed. Poland - max 120kbps :/
Old 09-29-2017, 07:45   #41 (permalink)
Member: 2762598
Hi. When I try flash phone using POLAND rom i got error:
S_DA_SDMMC_CONFIG_FAILED (0XC50)
same error I got when try flash using official ROM :
Android Info
 Build ID: MRA58K
 Display ID: MRA58K release-keys
 Version: 6.0
 Build Date: Wed Jul 20 22:35:24 CST 2016
 Build Date: 1469025324
 Model: 5045X
 Brand: TCL
 Device: PIXI4_5_4G
 Manufacturer: TCL
 Region: IT
Android Info END
Any idea what can be wrong?
Ps. I can't paste full text from file - system see it as links...
Old 12-12-2017, 03:59   #42 (permalink)
Member: 2766706
worked like a charm , ty laura for help and Brka for rom
Old 05-26-2018, 21:18   #43 (permalink)
Member: 2729693
Orange Rise 51 ( Alcatel One Touch 5045Y
I need stock firmware for Orange Rise 51 (Romania) PID : 5045Y-2ARGRO3
Model: Orange-Rise51
Build Id: MRA58K
Platform: MT6735
Android Version: 6.0
The Following User Says Thank You to Byrryandy For This Useful Post:
Old 06-23-2018, 00:20   #44 (permalink)
Member: 2846252
please the firmware for 5045Y IMI TREBUI SIMIE NEAPARAT FIRMWARE DE LA ALCATEL 5045Y
Old 06-23-2018, 07:25   #45 (permalink)
paulbs's Avatar
Member: 74719
Sonork: paulelectro
Thanks Meter: 181
MT6735__Orange___Orange-Rise51__PIXI4_5_4G__6.0__CONTRA COST
Page generated in 0.36150 seconds with 10 queries
