Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 01-30-2015, 23:07   #1 (permalink)
Member: 1839716
Thanks Meter: 2
Exclamation OT-4033X pro_info Help
hello,
i need same help with this phone i already changed PID to unlocked one
4033X-2AM3DZ1 To 4033X-2DALFR1-1
but i don't find how to downgrade version in file to force Mobile Upgrade do her job, it say not update
https://www.sendspace.com/file/0tgosv
Old 01-31-2015, 00:39   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by djamelXm View Post
hello,
in your file : S6JD16CJKOXRDR1SAA27B0AS10C10A1
play with red part ... try AJ5 etc. (lower letters and numbers)
(DA0, CA1, etc. - i found AJ5 in 4030x pro_info )
or ... use 4030x pro_info, just edit pid, and try, and post results.
p.s. ALWAYS MAKE FULL BACKUP and NVRAM BACKUP before playing !!!
(search my post in this section how to do it with SPFlashTools)
b.r.
Alex
Old 01-31-2015, 10:53   #3 (permalink)
Member: 1839716
Thanks Meter: 2
Thank you for reply
Other PRO_INFO files for the phones in Thread always give the same message no new update , & i have tried to manipulate the value DR1 but not much new
I will keep trying until I find the value of allowing update
thanks again
Old 01-31-2015, 17:21   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Bro,
Lets make things simple. What you want to do with that phone?
Decustomize? Unlock? Put other rom?
Write what you want to do, i will try to help.
B.r.
Alex
Old 01-31-2015, 19:56   #5 (permalink)
Member: 1839716
Thanks Meter: 2
I only need update the phone with european french ROM uncustomised
Current one has many bug like battery life and his slow
Old 01-31-2015, 20:16   #6 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Ok, so, the pid is one from the picture above ? (4033X-2DALFR1)
don't worry, I will find you rom, stay tuned, need some time to assemble
all files and upload it.
b.r.
Alex
Old 02-01-2015, 10:00   #7 (permalink)
Member: 1839716
Thanks Meter: 2
Thank You,
Yes my original PID is 4033X-2AM3DZ1 this Rom is very bugi
and this one look good 4033X-2DALFR1-1 clean Stock
Old 02-02-2015, 00:44   #8 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Thank You,
Okay, HERE is your rom file, with flasher included.
Open SPFlashTools, open scatter file from ROM folder, press download, and attach powered off phone to cable.
If you didn't install the drivers earlier, you can simply install
alcatel OTU updater, it will auto-install the drivers. get it - HERE
Post resultsl. Also there is thanx button in bottom right corner, use it if this helped.
b.r.
Alex
The Following User Says Thank You to Brka For This Useful Post:
Old 02-04-2015, 12:30   #9 (permalink)
Member: 1839716
Thanks Meter: 2
after 2 days of test the ROM is perfect no customization a good battery life
thanks again for your help
and he passed with
SP_Flash_Tool_v3.1344.0.212
and this scatter file
https://www.sendspace.com/file/vlt41z
The Following User Says Thank You to djamelXm For This Useful Post:
Old 07-16-2016, 01:38   #10 (permalink)
Member: 2596948
Hello Brka, please I need you to help me reupload this 4033x rom. I downloaded the one from the mediafire link but the custpack. img, mobile_info. img, recovery. img, secro. img, system. img and info. nfo files are corrupted when I unpacked the package.
Thank you.
Old 07-16-2016, 16:24   #11 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Files are okay, use 7zip to unpack it, or if you have isp problems,
Download it again on different pc/isp
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 07-18-2016, 09:56   #12 (permalink)
Member: 2596948
Thanks a lot. It worked.
Page generated in 0.23331 seconds with 8 queries
