Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
01-30-2015, 23:07 | #1 (permalink) |
Junior Member Join Date: Nov 2012 Location: Annaba,Algeria
Member: 1839716 Status: Offline Thanks Meter: 2 | OT-4033X pro_info Help i need same help with this phone i already changed PID to unlocked one 4033X-2AM3DZ1 To 4033X-2DALFR1-1 but i don't find how to downgrade version in file to force Mobile Upgrade do her job, it say not update https://www.sendspace.com/file/0tgosv |
01-31-2015, 00:39 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
play with red part ... try AJ5 etc. (lower letters and numbers) (DA0, CA1, etc. - i found AJ5 in 4030x pro_info ) or ... use 4030x pro_info, just edit pid, and try, and post results. p.s. ALWAYS MAKE FULL BACKUP and NVRAM BACKUP before playing !!! (search my post in this section how to do it with SPFlashTools) b.r. Alex | |
01-31-2015, 10:53 | #3 (permalink) |
Member: 1839716 Status: Offline Thanks Meter: 2 | Thank you for reply Other PRO_INFO files for the phones in Thread always give the same message no new update , & i have tried to manipulate the value DR1 but not much new I will keep trying until I find the value of allowing update thanks again |
01-31-2015, 17:21 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Bro, Lets make things simple. What you want to do with that phone? Decustomize? Unlock? Put other rom? Write what you want to do, i will try to help. B.r. Alex |
01-31-2015, 20:16 | #6 (permalink) | |
don't worry, I will find you rom, stay tuned, need some time to assemble all files and upload it. b.r. Alex | |
02-02-2015, 00:44 | #8 (permalink) | |
Open SPFlashTools, open scatter file from ROM folder, press download, and attach powered off phone to cable. If you didn't install the drivers earlier, you can simply install alcatel OTU updater, it will auto-install the drivers. get it - HERE Post resultsl. Also there is thanx button in bottom right corner, use it if this helped. b.r. Alex | |
The Following User Says Thank You to Brka For This Useful Post: |
02-04-2015, 12:30 | #9 (permalink) |
Member: 1839716 Status: Offline Thanks Meter: 2 | after 2 days of test the ROM is perfect no customization a good battery life thanks again for your help and he passed with SP_Flash_Tool_v3.1344.0.212 and this scatter file https://www.sendspace.com/file/vlt41z |
The Following User Says Thank You to djamelXm For This Useful Post: |
07-16-2016, 01:38 | #10 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2596948 Status: Offline Thanks Meter: 0 | Hello Brka, please I need you to help me reupload this 4033x rom. I downloaded the one from the mediafire link but the custpack. img, mobile_info. img, recovery. img, secro. img, system. img and info. nfo files are corrupted when I unpacked the package. Thank you. |
07-16-2016, 16:24 | #11 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Files are okay, use 7zip to unpack it, or if you have isp problems, Download it again on different pc/isp
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
