Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 02-17-2015, 00:35   #1 (permalink)
Member: 2347029
Cool Alcatel 5020x ROM, Unbrick, pro_info etc.
Hey guys can please someone explain how can I backup the "pro_info" file from my phone??
According to whats written on the back my phone is 5020X-2ATBGR1
I have installed some roms and now I want the official one cause the one I backed up failed..
And BTW I would prefer the unlocked US/UK version?
Thanks a lot!
Old 02-17-2015, 21:15   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Hi,
you can read pro_info with SPFlashTools ,
like I already mentioned in many posts.
Open SPFT, go to scatter-loading, load attached scatter file,
go to memory read tab, press add, select where to save file,
name it 5020x_pro_info,
start address : 0x3140000
length: 0x300000
press read, connect powered off phone to cable.
p.s. There is no 5020x model for USA, just 5020T / 5020W / 5020A / 5020N
you can try "A" model, should be same hardware, others are not compatible.
5020A-2[X=A,B,C,D,E,F,G,H,I,J]LDUS1
try playing with pro_info, it can bring succesfull results.
b.r.
Alex.
File Type: txt MT6575_Android_scatter_emmc_5020x.txt (584 Bytes, 433 views)
The Following User Says Thank You to Brka For This Useful Post:
Old 02-19-2015, 13:38   #3 (permalink)
Member: 2347029
Thank you very much!
When I get back from work and find some time I'll give it a try.
Old 02-20-2015, 13:50   #4 (permalink)
Member: 2347029
Hey Brka..
Here is my pro_info.
www(.)sendspace(.)com/file/kjk5uz
I tried playing with the 3 digits (HC3) right before "SAA" but didnt help
OTU still says I have the latest version already installed.
Btw I have a custom rom installed through CWM.
Could that be the problem?
What I need is to get the stock rom from OTU..
Thanks again for your help.
Old 02-20-2015, 18:41   #5 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Originally Posted by piperatdawn View Post
Hey Brka..
Hm, strange.
However ... Write me here which rom you want ... original one ?
b.r.
Alex
Old 02-21-2015, 16:27   #6 (permalink)
Member: 2347029
Hey Alex,
I know it is strange since i tried all the possible combinations.
Btw i used latest version of SPFT 5.1352.01
Anyway yes i need the original rom.
I have a CWM backup but its not working.
Regards,
Ian
Old 02-21-2015, 16:45   #7 (permalink)
Member: 2347029
Oh and one more thing..
I now use a custom rom and since I wasn't sure this would work,
I didn't format the phone.
Is it necessary to format in order for OTU to see an update??
Regards,
Ian
Old 02-21-2015, 22:28   #8 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Regards,
Ian
Never do FORMAT from SPFT, before making FULL ROM_0 backup,
you can damage the phone.
Yesterday I had one 5020x, and I read pro_info before and after update,
you can check it, and maybe use pro_info (just edit PID) before I did update,
it should allow you to update phone, too.
If you look closer both files, something else has changed, not that first line.
And, that is - factory software versions of system, custpack, etc.
You can further check, from second pro_info_upgraded file,
here is the list of files, that OTU put into phone :
c2acef71ab00.mbn
D2AC7070AB00.mbn
E2AC7070AB00.mbn
G2AC7070AB00.mbn
H2AC7070AB00.mbn
I2AC7070AB00.mbn
J2AC7070AB00.mbn
KAC7EMMC.sca
l2acef71ab00.mbn
M2AC7070AB00.mbn
N2AC7070AB00.mbn
P2AC7070AB00.mbn
R2AC7070AB00.mbn
S2AC7070AB00.mbn
U2AC7070AB00.mbn
x2a0ef01ab00.mbn
Y2AC7070AB00.mbn
B2AC7070AB00.mbn
Files Legend:
BOOTIMG=B2ACE0E0AB00.mbn
DSPBL=D2ACE0E0AB00.mbn
EBR1=E2ACE0E0AB00.mbn
EBR2=G2ACE0E0AB00.mbn
CACHE=H2ACE0E0AB00.mbn
MOBILEINFO=I2ACE0E0AB00.mbn
EBR3=J2ACE0E0AB00.mbn
SCATTER=KACEEMMC.sca
MBR=M2ACE0E0AB00.mbn
EBR4=N2ACE0E0AB00.mbn
PRELOADER=P2ACE0E0AB00.mbn
RECOVERY=R2ACE0E0AB00.mbn
USERDATA=S2ACE0E0AB00.mbn
UBOOT=U2ACE0E0AB00.mbn
ANDROID=Y2ACE0E0AB00.mbn
CUSTPACK=c2acoce0ab00.mbn
LOGO=l2acoce0ab00.mbn
SECRO=x2a0oc00ab00.mbn
It's from other pid, but starting letters are important, ie:
B***** = boot.img
Y**** = system.img,
C**** = custpack.img, etc.
Things that changed in pro_info :
before upgrade          -     after upgrade
AAUY2AAU0U0AB00   -    AAUY2AC7070AB00
C2AAEFU3AB00         -    c2acef71ab00
X2A0EF03AB00          -    x2a0ef01ab00
L2AAEFU3AB00          -    l2acef71ab00
KAAUEMM                 -     KAC7EMMC
and ... info from service softvare, about versions (before/after):
original AAUEFU3 / available AC7EF71
So .... all this can be seen in pro_info .... and in this case,
AAU and AC7 are software versions (latest is AC7, AAU was in phone).
Conclusion: try with my attached pro info, just change PID,
or, play with your pro_info - in your file is : AATY2AAT0T0AB00
try changing that red part, into some lower - ie: AAA or AAU
and retry operation with OTU updater, lets see what will happen,
looks like my sticky thread is totally wrong ... but we will correct it.
You need to do some research for me, it's not problem about ROM,
I will upload it for you, but let's see what will happen with all this pro_info stuff.
Dont forget to post results and progress.
b.r.
Alex
File Type: rar 5020x_pro_info_before_and_after_upgrade.rar (3.9 KB, 316 views)
Old 02-22-2015, 17:45   #9 (permalink)
Member: 2347029
Hey Alex,
I tried some changes in my pro_info according to your last post but with no success.
I also tried with your pro_info files (upgradeable and upgraded) and still nothing!!
The upgradeable pro_info you sent me should have worked right??
Seems like something else is going on here!?!?
Last edited by Brka; 02-22-2015 at 20:51. Reason: sry, no thanks in posting. use thanks button.
Old 02-22-2015, 21:59   #10 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Hey Alex,
Strange... Looks like I still don't have all answers.
I attached edited pro_info, you will try that first, to see if it will work.
Second ... if above didnt work,
Grab your ROM file - HERE
SPFlashTools - HERE
Follow the standard procedure :
- Unpack ROM, Unpack SPFT.
- Open SPFT, go to scatter loading, load scatter from unpacked ROM folder
- Select manually all files that are not ticked (custpack, ebr3, mobile_info, ebr4)
- Connect powered off phone to SPFT, wait for flashing done.
- After Finish (Green circle and OK), disconnect/reconnect battery
- Power on the phone, wait for it to start.
- Done. You have working phone with desired languages.
p.s. About real, FULL ROM backup :
- Open SPFT, load scatter file
- Tab "Read Back", remove if any existing there,
- Press ADD button, double click on added,
- Select save location, name the file ie: "My_5020x_FULL_BACKUP.bin"
- Start address : 0x0000000000000000 (default) , length : 0x3764c000
- Press READ BACK, and connect powered off phone to cable
- Wait for finish, it will take some time ...
After done, you have SPFT FULL backup, which will, in ANY case,
get your phone back to working state, with original imei and all.
(if you want all that + ALL USER DATA etc - put in address length : 0xFFFFFFFF,
but it will need couple of hours to read it all 4Gb rom ...)
That rom files, are writable via "Window -> Write Memory (enable) - Write Memory TAB.
b.r.
Alex
Old 02-23-2015, 02:10   #11 (permalink)
Member: 2347029
Ok thanx for your help Alex!
Ill try it tomorrow and post results!
Regards,
Ian
Old 02-23-2015, 16:18   #12 (permalink)
Member: 2347029
Hey Alex,
The pro_info you sent me didn't work but after researching a bit more I came up with some strange results..
So I tried the pro_info files attached to your sticky post and they worked!
These files: (www(.)sendspace(.)com/file/rw7hf6)
I thought I had tried them before so excuse me about that!!
Now the interesting thing is that after trying various combinations,
in order to see where those files are different compared to my original pro_info,
I found out that the only thing that needs to be changed in my original pro_info are these letters!
RIW5020X-2ATBGR1
So whenever I change it to something like this
RIW5020D-2AALGR1
OTU starts the upgrade!!
Though by doing this OTU might think I have a different phone.
But then again maybe I can run the update like this and then change it back to 5020X and update again!
Whenever I use 5020X its not working!
I don't know the combinations that exist though, so this might be the reason why.
The thing is that my phone is not a dual sim one so I dont know if I must proceed while its 5020D!
Hope this, will shed a bit of light in your research.
I'm still not able to understand what's going on
Regards,
Ian
Old 02-23-2015, 17:13   #13 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Hey Alex,
RIW5020X-2ATBGR1
RIW5020D-2AALGR1
Regards,
Ian
Just make a full ROM_0 backup, and you can play all day long.
Yes, you can update it with 5020D, it's same hardware,
all will work, except second sim.
Question is, when you update it with 5020D,
and after try to return it to 5020X, what will happen.
i found pro_info from 5020A ... attached.
if you want, try with it, too, change PID/Model and see what will happen.
b.r.
Alex
Old 02-23-2015, 20:58   #14 (permalink)
Member: 2347029
Hey,
I made a full backup as you told me..
Wish I had make one and not trusted the CWM backup..
Still don't know what went wrong with that..
Anyhow 5020A pro_info works as well.
As before I only need to change the PID though not the whole pro_info..
Is there anywhere I can get all the 5020X PIDs? And maybe provider and country info?
I'm now upgrading via OTU. Seems its gonna take a while.
I'll try and change back to 5020X after its done!
I'll post results..
Regards,
Ian
Old 02-23-2015, 21:12   #15 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
ot-5020x FULL PID list :
5020X-2[X=A,B,C,D,E,F,G,H,I,J]2DNZ2
5020X-2[X=A,B,C,D,E,F,G,H,I,J]S7RS1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]G4GA1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TNHU3
5020X-2[X=A,B,C,D,E,F,G,H,I,J]M9MZ1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALNL1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]AMMA1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]RGML3
5020X-2[X=A,B,C,D,E,F,G,H,I,J]RGTE3
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TBHU1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TBNL1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TBNL2
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALBY1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]BHBA1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TBAL3
5020X-2[X=A,B,C,D,E,F,G,H,I,J]VIHI1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALIB1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALDZ1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]RGDO3
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TIVE3
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALGB1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TBCZ1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TBMK1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]2DNZ1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TEHR1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]RGES3
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TNME3
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TNRS3
5020X-2[X=A,B,C,D,E,F,G,H,I,J]KPNL1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]CFMK1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]VDMK1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALMT1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]TBGR1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]C9PC1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALEU1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALFR1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALBE1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALEG1
5020X-2[X=A,B,C,D,E,F,G,H,I,J]ALAP1
Page generated in 0.29254 seconds with 9 queries
