Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 04-04-2015, 20:43   #16 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by master_byte View Post
i tested this version and it is the "110FFN1" and cant' update to latest version "290FFN1". but it works...
i need this version of firmware "290***1" . i don't care what country is the firmware, because i can change the language to portuguese.
or find the way to force OTA updates...
what is OTA updater saying, when trying to update ?
I aks this, because on support, files have totally different naming scheme,
I cant easily say which rom is which version,
you can check in attached .nfo file, original file names ...
no idea which one is which version ....
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 04-06-2015, 13:09   #17 (permalink)
Member: 1267940
Thanks Meter: 2
The OTA says that i have the latest version, but the portuguese vodafone support say's that the latest version is "290FFN1" and i asked on 2 different foruns what is the software versions on their devices and all are using the "110FFN1".
This must be "special update", but my warranty is gone...
This is frustrating and i'm going to use the alcatel S7 firmware on my device.
Old 04-14-2015, 20:14   #18 (permalink)
Member: 2379047
please, can you upload the stock firmware for the V985N - 2BVDDE1 ?
or can you tell me, where i can download it?
Old 04-15-2015, 19:48   #19 (permalink)
Member: 2379581
Good afternoon. Please, can I ask for stock ? V985N-2BVDCZ1
Old 04-15-2015, 19:49   #20 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by DittmannCZ View Post
Good afternoon. Please, Iwhere can I find my PID? (do not laugh so laud)
It is usually written on the sticker (under battery),
or on phone box, for your phone : V985N-2XXXXXX
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 04-15-2015, 20:07   #21 (permalink)
Member: 2379581
Yes, V985N-2BVDCZ1.. or english, whatever.. OTA updates fails with some .ZIP match error
Old 04-16-2015, 10:18   #22 (permalink)
Member: 1267940
Thanks Meter: 2
Brka it is possible to find what is the latest firmware for 985N, or all regional versions have the same version?
Old 04-16-2015, 16:32   #23 (permalink)
Member: 2379581
Rescued, Thank You for all hints!
Old 04-24-2015, 02:00   #24 (permalink)
Member: 2383877
Hi Brka,
If we all flash the very same ROM, will we get same BT and WiFi MAC address?
Thx
Old 04-24-2015, 17:37   #25 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Mac address is irrelevant. You can all have same mac addresses, and untill you all guys meet at same place, it will work normal, because first gateway/rooter loose src mac address.
All that is visible outside router is router's wan mac.
Regarding v985n ... I dont understand why all of you are tied to branded vodfone firmwares,
When you can make your phones into regular 7045 models.
I waited the day when cwm recovery was out for my 6016x,
And first day it came out, i put some unbranded rom + root,
Deleted over 500mb of crap from system, and i was happy.
And btw, i am very sure that regular 7045 have latest possible updates,
And less bugs than any branded firmware.
I already offered some latest firmwares, but hey, you are too much
Reading other forums, and want some 300xxxx update...
I cant help with that. Factory versions naming scheme is different
Than what you seez and i dobt have time investigating
Which version is which.
B.r.
Alex
__________________
Old 04-24-2015, 17:51   #26 (permalink)
Member: 2383877
After googling I found that some users of other models
have the same problem. It seams that on first boot a scan probe the hardware to get MACs and write on a config file. If the file already exists, it's not rewriten.
If two users flash a ROM where that file exists, both get same MAC.
Hi Brka
I agree with you regarding 7045. I what to drop vdf ROM. But MAC address is not irrelevant. I have several work colleagues that work on same office. Two of us flashed 7045 using sp flash tool and we got the same MACs. Trying to send files to each other over BT was impossible even after renaming our BT device name. We then try to send to a different phone and it worked. WiFi was having problems too but we thought that was due to signal strength.
Cheers
Old 04-24-2015, 19:49   #27 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by droidroid View Post
Hi Brka
Cheers
We are now discussing a trivial things.
EDIT: Still investigating mac address issues.
b.r.
Alex
__________________
The Following 3 Users Say Thank You to Brka For This Useful Post:
Old 04-25-2015, 22:02   #28 (permalink)
Member: 1267940
Thanks Meter: 2
Results... if i am using the alcatel rom i canīt recover from vodafone backup. puts the phone in bootloop. Same result using the vodafone rom and using the alcatel recovery.
The alcatel recovery is 01004 and not 01005 like you mentioned...
i am waiting for your backup....
Old 04-26-2015, 22:33   #29 (permalink)
Member: 2383877
Hmm... why are you after VDF ROM? Like Brka said, Alcatel it's better, right?
Can someone post an 1004 (or newer), to be flashed with SPFT, where we *all* ended with different Wi-Fi and BT MACs? Or is it really impossible?
Once again, like Brka said, we can do a backup of original NVRAM before doing it (although I don't have it anymore) but I'm sure that's not the way it should be done.
At least, every ROM that came from factory on a new phone, have different MACs.
Besides, not every colleague at work have necessary skills to 'play arround' with SPFT and I'm afraid that we all end with same MACs, disrupting comms in office ;-)
Thank in advance!
Old 04-26-2015, 23:05   #30 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Thank in advance!
I tried, but looks like I still don't understand people
Anyway ...
I hope tomorrow I will get more time, and fulfill everyone's wishes,
with both V985N rom and original 7045x ROM's,
so you can do whatever you want.
Also, if some of you can provide one NVRAM backup,
I can check, and show you what to edit.
(you can upload it and send link to PM, if you are afraid about your IMEI / identity info's)
b.r.
Alex
__________________
Page generated in 0.39019 seconds with 8 queries
