Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
06-25-2015, 09:29 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Vodafone Vf685 upgrade help. i do have this phone Vodafone vf685 which is look like an Alcatel phone. this phone have provider id as same as alcatel phones.this phone have hang on logo problem.so i decide to upgrade or flash.but on forum or any where i can't find rom or flashing method for this phone.i check on OTA software there is no model number of this phone on list.but one thing i do have same phone with same provider id on working condition so if any one specially sir Brka can help me about it it will be really great for me. some details of phone. Model.Vf 685 smart kika Provider id.v685-2AVDZA1 Last edited by ij_cell; 06-25-2015 at 09:35. |
06-26-2015, 20:08 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Phone is same hardware as 4018A/D/E/F/M/X. Use SPFlashTool v3.1344.0.212 , load attached scatter, tab READ BACK, ADD, select save location and file name, start address is 0x0000000 , end address is : 0x55380000, press Read Back and connect powered off, working phone to cable. After done, from SPFT, Window, Write memory, load file, select eMMC, open raw data, Write memory, connect powered off phone to cable. that's all. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 06-28-2015 at 19:02. Reason: removed Quoting |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
06-27-2015, 08:21 | #5 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Vodafone 685 and Vodafone 785 have 3 hardware versions. Flashing wrong firmware will result boot on logo or dead handset. PID difference no matter here. Flashing full, is not recomended, only to make alive phone. Some items are build at first start if missing. bad values can cause bad signal, wifi problems e.t.c e.t.c. |
06-27-2015, 08:37 | #6 (permalink) | ||
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Quote:
Done. Read back. Write back. Quote:
Br. Feefi fb Last edited by Brka; 06-28-2015 at 19:01. Reason: no thanks in posting, use thanks button. | ||
06-27-2015, 09:14 | #7 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | You was lucky Is great you solved your problem, was 2 phones with save pcb revision. And you not readed my repply As example, exist for VDRO1 2 distinct versions ACC2 and MR. Buth firmwares for same pid VDRO1. Flashing ACC2 firmware in phone what haved MR firmware will be dead phone. VDRO1 is taked as example, can be another PID |
06-27-2015, 09:22 | #8 (permalink) |
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | I understand what you mean.i will be careful next time. Last edited by Brka; 06-28-2015 at 18:59. Reason: no thanks in posting, use thanks button. |
06-27-2015, 14:46 | #9 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | As far as hardware is okay, software problems can be solved. @ij_cell Open 4007x scatter file in text editor and see address for cache partirion, Thats end address for reading. B.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
06-27-2015, 14:50 | #10 (permalink) |
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | And what would be the start address?and iam still not sure about same methode with Alcatel 4007x for flash Last edited by Brka; 06-28-2015 at 18:59. Reason: removed quoting |
06-27-2015, 17:02 | #11 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
b.r. ALex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
07-03-2015, 19:37 | #12 (permalink) |
Junior Member Join Date: Sep 2013 Location: South Africa Age: 37
Member: 2016443 Status: Offline Thanks Meter: 4 | I need a ROM for Vodafone VF685 please. Also, can you advice if fixing the logo hang problem here http://forum.gsmhosting.com/vbb/f317...-help-1962533/ require flashing of a firmware or you do not use any. Thanks. I got the one for the 4018A supposed to be compatible with the VF685 , could it be the same pack you used? Last edited by Brka; 07-03-2015 at 21:30. Reason: consolidating forum space |
07-03-2015, 21:32 | #13 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Yes, it requires flashing. Hardware is compatible with 4018a, rom link already posted HERE b.r. Alex
07-04-2015, 10:18 | #14 (permalink) |
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Here is readed firmware link. For flash phone please everyone read this thread from start. http://www.filedropper.com/vf685 Provider id of this file is : V685-2AVDZA1 Last edited by Brka; 07-06-2015 at 23:14. Reason: merged for better visibility |
The Following User Says Thank You to ij_cell For This Useful Post: |
08-16-2015, 06:23 | #15 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Quote:
------------------ https://mega.nz/#!tJIXVYYR!oT65mPZiz...UbQMJy5aCGPl08 | |
