Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > Motorola Hardware Repair Section
Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing.
Old 07-22-2005, 12:53   #1 (permalink)
Member: 136288
C350 - keypad not working - help please
C350 will power on and receive calls but no keys work (except power on) after water damage. Display is also OK.
I expected maybe some keys not to work but not ALL of them!!
I dismantled phone and it is now completely dry.
Can some kind person please help - it's my son's phone.
Old 08-06-2005, 19:43   #2 (permalink)
Member: 136288
2 weeks and nobody has any ideas? I can't believe it!
Come on helpers - there must be something I can try?
Old 08-14-2005, 18:45   #3 (permalink)
Member: 136288
Has nobody had this problem?????????!!!
Old 08-19-2005, 12:28   #4 (permalink)
Member: 59030
when you have water damaged phone, you cannot simply dry it and expect it to work. disassemble the phone, remove lcd and clean the board with brush and soap thouroughly, after that **** dry completely with hair dryer and put it back together, it should work
Old 08-22-2005, 10:46   #5 (permalink)
Member: 173300
PCB dammaged Pls check carefully.
Old 08-27-2005, 17:30   #6 (permalink)
Member: 136288
Hi Citifone!
I did what you said, gave it a thorough clean and ****dry, but no luck.
It's the same as before - only power on key works, receives calls, and display is fine.
Any other ideas are very welcome!!! (Please!)
5130c keypad not work help solution fuad15 Nokia Hardware & Hardware-Repair Area 23 10-01-2012 10:08
6610 keypad not working ? help me amitks_in Nokia Hardware & Hardware-Repair Area 8 09-15-2009 16:43
c5-2m keypad not work help raoul plus Sagem Hardware Repair Area 0 08-23-2009 20:47
N73 keypad not working help needed Tahir Riaz Nokia Hardware & Hardware-Repair Area 3 05-04-2009 09:35
t610 keypad not working - help jasko Sony Ericsson Hardware Repair Area 1 03-18-2004 20:02
Page generated in 0.25109 seconds with 11 queries
