Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 02-11-2009, 18:35   #1 (permalink)
Member: 562132
Thanks Meter: 86
help me moto k1 no tunes working but speaker is working
and i think that it softwar but i give it many version of softwar
but tunes stell not working
and i do prepair phone and no result
Old 02-11-2009, 21:26   #2 (permalink)
Member: 905846
Thanks Meter: 26
Joining the question.
Had more then 2,000 of them directly from the production line (new and original). At least 3 where with that problem.
I suspect that MP3/MID encoder inside the processor is damaged or a cold soldering (after all they where all new).
Never encountered similar problem in Motorola.
Anyone have an idea or directions?
Old 02-12-2009, 15:52   #3 (permalink)
vishal123123's Avatar
Member: 463150
Thanks Meter: 91
this is a very common problem with motorola k1. but still now not received any solution from any of the member
Old 02-12-2009, 17:04   #4 (permalink)
Member: 527976
Thanks Meter: 2
i think the problem is in the flexible board to display,i have that problem to yesterday....,then i replace the flexible with the new one and then the problem solved.............
The Following User Says Thank You to yanee For This Useful Post:
Old 02-12-2009, 20:12   #5 (permalink)
Member: 905846
Thanks Meter: 26
Thank you, I'll try that on sunday and post here an answer
Old 02-15-2009, 08:47   #6 (permalink)
Member: 527976
Thanks Meter: 2
ok you can try that,but if that cant solve ur problem u can PM me because i work on motorola authorized service centre in indonesia........
Old 02-16-2009, 05:21   #7 (permalink)
Member: 905846
Thanks Meter: 26
I replaced the folder, it helped. thanx.
It's also helped the problem "When you try to check the ring and you have white screen adter the ring and every tune is ringing in a single tune" (hard to explain this problem, but this solution also helped).
Old 02-16-2009, 20:07   #8 (permalink)
Member: 562132
Thanks Meter: 86
It's also helped the problem ").
please i can,t anderstan what,s folder you mean
and i want to now what is flexable ?????
Old 02-16-2009, 21:41   #9 (permalink)
Member: 905846
Thanks Meter: 26
hmmm.... folder is the k1 without the main board. "Replaced the folder" meaning I took two k1's and replaced their caseing with each other.
"Flexable" its a flexebale strip that connect the main board to the outer plastic.
Old 02-16-2009, 23:05   #10 (permalink)
sajidashraf's Avatar
Member: 501674
Sonork: THEIF OF HEART
Thanks Meter: 879
your problem is 100% software br... try full flash.....
Old 03-28-2009, 05:55   #11 (permalink)
Member: 562132
Thanks Meter: 86
thanks for all
very very thanks
i have replaced with new flexable and it now working done
and ihave doing that in two moto k1 with the same problem and solved by reblac flexabe
thanks for all
The Following User Says Thank You to almalizy For This Useful Post:
Old 01-28-2010, 20:32   #12 (permalink)
Member: 984046
Thanks Meter: 253
I know that this is long time ago post, but....
I had some weird buzzer problem... (phone was ringing normal on some sounds, but on some was only heavyly distorting)
Flex/Flat change solved problem... (after buzzer speaker change & full flash serveral times)
It looks that audio amp driver is on upper board of handset...
Haltec
s109 no network bar but network is working vinod kukreja Various CDMA/TDMA Cell Phones 1 09-18-2009 09:22
plz help me lg kg110 ringer is ok but speaker is not working pls help me any one jodhpur_raj LG Hardware Repair 7 11-01-2008 14:37
lg kg110 ringer is ok but speaker is not working pls help me any one jodhpur_raj LG 0 10-09-2008 14:17
moto L6 no sound from earpeice , speaker is fine bayleaf Motorola Hardware Repair 0 04-29-2006 20:32
Page generated in 0.37323 seconds with 8 queries
