Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > Motorola Hardware Repair Section
Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing.
Old 12-05-2001, 00:09   #1 (permalink)
Member: 6263
Red face Help!!! Problem with motorola V3688/3690
On my 2 motorolas v3690 and v3688, I broke the displays... so I decided to buy a new ones... I dissassembled correctly the phone... quit the flex cable and etc... (disconnected the ground on the screen... after that, I put the new displays... soldered the display GND and so... but with surprise, THERE'S NOTHING ON THE SCREEN!!! nothing, I checked the connectors, but nothing... and no beeps, no speaker, no led ignition and no display. But I know the phone works, because the main pcb works, if I use a hands free works... Can anyone help me??? It's strange to crash the 2 phones at the same time/way... so please help me.
Many thanks in advance and best regards,
Toldien
Old 12-05-2001, 08:33   #2 (permalink)
D-Brain's Avatar
Member: 7301
Post
You can try to clean and/or resolder the Flat-cable connector on the PCB , or if you can.. try another LCD , maybe you have 2 defective LCD?!?
Old 12-05-2001, 23:21   #3 (permalink)
Member: 6781
Post
did you bye..corect version of display...there is many versions of displays..and flats...look at the back of flats...you are going to see a diference <img src="smile.gif" border="0"> )))
Old 05-08-2003, 15:52   #4 (permalink)
Registered User
Member: 10672
take very care on dissasembly ..there are some resistors in front of plastic closers of the case, so if u use on opening some inadecvate tool u could remove them , so ur phone doesn't start anymore....check them with strong light and strong glasses. Try 2 resolder them again.
Old 05-16-2003, 00:31   #5 (permalink)
SVH
SVH's Avatar
Member: 9889
i can tell you interest info about cables
i had similar situation: i got V3688 with bad cable so i decided to change not full display but just cable
i bought cable, soldered correctly and tried to power on but on display was nothing and display ic was little hot
i compared 2 cables and found that position for 1 capacitor and 1 resistor(0 Ohm) are differend
so look carrefully on your new cable, compare with old and go to play new game "Find differences"
i sure you find them
b.r.
Old 08-31-2003, 19:53   #6 (permalink)
tob
Member: 19068
1. Put display connector deeper
2. Check R4 and C10, if they changed - nothing on display
3. R1 - contrast (my 270k)
Old 08-31-2003, 21:29   #7 (permalink)
Porter's Avatar
Member: 19633
Better to by flat cabel + lcd, because exist feu wersion LCD and flex cabel... theyu is not compatible, so better do as I say...
help need for motorola v3688 barbarianus Old Legacy Motorola (EMMI) 3 07-03-2004 08:14
motokey problem with old V3688 makona Old Legacy Motorola (EMMI) 5 01-28-2004 07:21
I have big problem with motorola t205 with charging can anybody help me ??? ZetMen ODM (Original Design Manufacturing) 3 09-11-2003 00:33
Help!!! Problem with motorola V3688/3690 toldien Old Legacy Motorola (EMMI) 5 10-20-2002 21:32
help on display mot v3688/3690 toldien Hardware Repair by brands 4 12-14-2001 08:30
Page generated in 0.42557 seconds with 11 queries
