Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
11-11-2007, 15:16 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Spain Age: 42
Member: 30296 Status: Offline Thanks Meter: 8 | Help with W510 Please, help me. Thanks in advance P.S.: To solve error "error9b" you have to do the 2 TP. |
12-16-2007, 11:48 | #2 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | Searching for phone... found Motorola Phone (W510), getting test interface... OK Model W510 Firmware R452G_G_08.13.09R Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.50 Sending boot... OK Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F9298B3B0B91B383.bk_ Searching for phone... found Motorola Phone (W510), getting test interface... OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.50 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M30L0R8000T0, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 490,W510,Z3 Hardware IMEI: 357338010186966 IMEI OTP status: locked Security area saved to "PDS for S Flash Neptune LTE2 357338010186966 (1).mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F9298B3B0B91B383.bk_ Restore OK Unlocking phone... error 9B same here whats wrong |
12-16-2007, 22:35 | #4 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | Quote:
05-16-2008, 09:36 | #5 (permalink) |
No Life Poster Join Date: May 2005 Location: Timisoara Age: 43
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | connect smart clip box to proper adapter (order from china) connect s-card power on the phone /// battery must be full connect data cable to box and then to phone search phone found prepare smart test point wait until software prompt you disconnect phone from data cable dismantle phone cut shield over testpoint area connect proper testpoint (USE TP VER 2 ONLY) /// order from china REMOVE FLEX CONNECTOR FROM BOARD connect data cable connect positive hook from tp to positive from board connect tp to board (as show in tp pic from www.boot-loader.com) hold tp until software told you to remove it restore backup file (that smart-clip has done when you prepare smart testpoint) //software will announce you when to do that PHONE UNLOCK if you connect your phone in boot loader mode, sometimes you must flash your phone after unlock, so the phone can power on ///again software will announce you if you must do this step ps :is not easy but it can be done if you use this step by step |
06-24-2008, 09:30 | #7 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 48
Member: 173417 Status: Offline Thanks Meter: 12 | I WANT TO TELL SMRT CLIP TEAM THAT THERE IS SOME PROBLEMS WITH W510 BECAUSE I HAVE UNLOCKED ONE SUCCESSFULLY BUT YESTERDAY I HAVE ONE IS DEAD Thanks to a l'aide de Mr. Christophe <[email protected]> for translation to Francais! SmartMoto 3.14 S-Card: 69***xx95 Smart-Clip dongle, v 2.08, assigned Smart-Clip: 558***xx49 Europe, Remise a 0... OK Smart Adaptor: serial 366339***X, firmware version 1.04 Numéro de série du clip : 55894***9, version: 4.07, Remise a 0... OK Recherche du téléphone trouvé S Flash Neptune LTE2, Interface test Interface non trouvé Passage en mode Flash... OK Lecture de boot version du téléphone. C.50 Envoie du Boot OK Échoué Délai io dépassé ONLY THE SAME WITH FULL BATTERY CHARGEDµ I TRY TO FLASH IT THE SAME I TRY TO UNLOCK IT THE SAME |
E72 keep restarting ..... any help with hardware solution?? | abu_nairoukh | Nokia Hardware & Hardware Repair | 4 | 12-14-2010 11:10 |
Need help with W510 | tito millo | Motorola Hardware Repair | 0 | 08-07-2008 16:22 |
Another problem with W510 unlock | fingusio | Smart-Clip | 2 | 03-26-2008 22:40 |
whats wrong with w510 | uqbah | Smart-Clip | 5 | 01-21-2008 19:37 |
problem with w510 | Santiago LEE | Smart-Clip | 1 | 12-06-2007 09:15 |
