Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
02-12-2009, 07:09 | #1 (permalink) |
Insane Poster Join Date: Mar 2007
Member: 459022 Status: Offline Thanks Meter: 10 | How To Repair Dead,Restart,Hang: motorola V3,v400,v300,v600,v500,v180,v220 Solution Dead no power First make sure your battery is 100% ok and charger If you cant seem to get it to power even with a external power supply Wont go to boot mode by pressing (hold and press +and# then power button) No responds with charger 1.Try to boot phone by pressing (hold and press +and# then power button) if its goes to boot mode try to flash phone if not step 2 2.Try to connect phone to smart-moto and check if phone is in flash mode already thats why it wont turn on 3.Reheat PA module or remove it and try to turn phone on without PA . if PA is shorted phone wont turn on or no responds at all with any power supply ( some shorted PA cannot be tested by a tester in battery terminal so I recommend that you take PA out , base on my experience ) Additional info Phone turns on then goes off rite away even with a charger Phone only turn on with a charger plug in Phone chargers but drains rite away 1.Its 100% PA problem to Signal problem Signal is good but cant make calls Call Failed and cant received calls No signal at al 1.Try to flex or full flash phone if you still get called failed or no signal 2.Try to reheat PA module if you still get called failed or no signal 3.Change PA module 100% PA problem , after change PA and still no signal full flash phone with ******* pack or any full flash 4.After that smile your phone is working Hang 1 Try master clear if still hangs 2.Full factory reset if still hangs 3.Try full flash phone if still hangs 4.Reheat PA or remove and observe phone with out PA module faulty PA causes software to hang Restart Phone restarts by it self , phone restart when making a call or receiving calls 1 Try master clear if still restarts 2.Full factory reset if still restarts 3.Try full flash phone if still restarts 4.100% faulty PA. |
10-28-2009, 08:04 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | I have a v3 that has the "8" number button pressing itself sometimes. I tried changing the keypad flex but the problem is still there. I also cleaned the flex cable contact of the cable and on the phone. How do i solve this pls |
MOTOROLA Dead,Restart,Hang V3,v400,v300,v600,v500,v180,v220 solution | JONONItelecom™ | Motorola Hardware Repair | 0 | 02-01-2010 01:24 |
How To Repair Dead,Restart,Hang V3,v400,v300,v600,v500,v180,v220 solution | meo786pk | Motorola Hardware Repair | 14 | 09-22-2009 18:11 |
HOW TO REPAIR DEAD V3 with rocker | gsmdz | Ultima Box Light | 4 | 04-01-2008 23:04 |
How to repair T610 Restart problem with UFS | .::Unlocker.:: | Sony Ericsson | 1 | 03-11-2007 15:57 |
How to unlock M55 without restpoint and How to repair dead phones. | halcon.cpu | E-Gold Based Phones | 10 | 06-19-2004 14:31 |
