Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
02-17-2007, 19:42 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Sargodha Pakistan
Member: 251247 Status: Offline Sonork: 1001670304 Thanks Meter: 192 | L7 Dead during TP procedure thanks. Munazzam. |
02-25-2007, 11:26 | #9 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Philippines Age: 52
Member: 167822 Status: Offline Thanks Meter: 13 | you washed with thinner and you did not detach the back up battery ? What tool did you use to cut the shield ? have you tested it 1st before doing unlock with TP ? L7 LCD is damaged if not disconnected when doing TP |
02-26-2007, 07:31 | #10 (permalink) |
No Life Poster Join Date: Feb 2005 Age: 44
Member: 115826 Status: Offline Thanks Meter: 391 | When the keypads lights on/off quickly is a sign that u soft r corrutp %60 ( Can be by severerals thing"s ) The phone no is death : keypads lights on/off quickly Use Usbsmart to repair the pds ( no use smartclip) . 1 . make a test point 2 . Repair the pds 3 . flash whit Rsdlite I whish u the best luck for u Last edited by Amartt; 02-26-2007 at 07:59. |
09-08-2007, 09:49 | #11 (permalink) |
Crazy Poster Join Date: May 2004 Location: HU
Member: 65657 Status: Offline Thanks Meter: 6 | Hi! I've got an error when put up a shield every thing is ok I connect phone with usb smart => Connecting to phone ... Connected to: 'Motorola Flash' Connected OK Bootloader version: 0300 Sending loader to phone ... ERROR: Not received READY ERROR: Send loader failed (2) and every time I try to connect without tp I get a same result: Connecting to phone ... Connected to: 'Motorola Flash' Connected OK Bootloader version: 0300 Sending loader to phone ... ERROR: Not received READY ERROR: Send loader failed (2) I rehot flash chip but the same So anybody can help me? Some info or any solution? Thanks Tybee |
E61 Dead Via Tp Procedure-help | zonetrichur | UID - Box | 5 | 12-11-2007 23:48 |
L7 dead after unlock without TP !!!! SC | Koca | Smart-Clip | 17 | 04-27-2007 03:06 |
Is there a step by step procedure for an L7 dead after Unlock ? | N/East Unlocker | Ultima Box Light | 6 | 01-25-2007 13:48 |
L7 dead during back up using testpoint | goffaman | Motorola P2k | 0 | 05-27-2006 12:06 |
L7 dead during unlocking | jabran | Smart-Clip | 29 | 03-18-2006 07:55 |
