Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 08-04-2015, 17:00   #1 (permalink)
uzzal10's Avatar
Member: 1319163
Sonork: no need...
Thanks Meter: 89
moto G not charging problem_ 0% only help me please...
moto g XT1032
not charging problem.....
when set off then show 0% only but set power on with charger..but don't connect to pc/leptop in fastboot mode...or set on mode...i am check connector, its ok.................
any big boss help me please.........
Old 08-04-2015, 18:17   #2 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 267
Smile replace charging cc
replace charging connector
original
and use 2amp any other brand like samsung htc or sony
100% tested solution
Old 08-04-2015, 20:37   #3 (permalink)
uzzal10's Avatar
Member: 1319163
Sonork: no need...
Thanks Meter: 89
original
Dear br.
Charging connector is 100% ok or charger is the high quality.......... Please moro idea...
Old 01-12-2016, 20:40   #4 (permalink)
Member: 333000
i also have a moto g that won't charge above 0% -- it looks like the diode on the V+ charging pin is burnt. Will update post once I replace this component.
Old 01-19-2016, 20:14   #5 (permalink)
Member: 1037764
Sonork: AQEEL22
hello friends ! have any one motorolla 912 charging ways please help
Old 01-23-2016, 09:54   #6 (permalink)
Member: 2492240
Check output voltage
Sent from my MotoG3 using Tapatalk
Old 01-28-2016, 04:50   #7 (permalink)
evasoft's Avatar
Member: 515830
Thanks Meter: 80
1,4v at batery conector
Old 02-15-2016, 19:25   #8 (permalink)
Member: 2509152
that is briked....search on youtube 100% ok solution.....i have solve thats problam few day ago....i have not premission to post link...
Old 02-17-2016, 13:29   #9 (permalink)
Member: 2261336
Sonork: rabee3
Old 03-07-2016, 08:39   #10 (permalink)
Member: 760204
Thanks Meter: 7
moto g 0% solution
check the battery voltage near 3.64 if no just booting the battery and you can connect charger it will ok.
Old 04-25-2016, 05:39   #11 (permalink)
Member: 2492240
Moto g2 not charging problem
Old 04-25-2016, 05:40   #12 (permalink)
Member: 2492240
Moto g2 not charging problem help me
The Following User Says Thank You to jayachandranjai For This Useful Post:
Old 05-11-2016, 17:31   #13 (permalink)
Member: 2301303
done
Old 06-23-2016, 15:56   #14 (permalink)
cbcelular's Avatar
Member: 217679
Thanks Meter: 95
need load solution I changed load connectors and not load or shows carrying motorcycle battery g2 xt1068
Page generated in 0.17389 seconds with 9 queries
