Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
01-13-2009, 08:54 | #3 (permalink) |
Insane Poster Join Date: Aug 2008 Location: Adip Telecom Syl Bd Age: 45
Member: 828093 Status: Offline Thanks Meter: 18 | motorola code #02#----handset information #03#----rf infomation #o4#----adc infor #08#----eng fild test mode #09#----simple test mode **0101#ffs format **0105#disable EFEM mode 1. Press 74663 (spells PHONE) 1. Press # MENU MENU quickly 2. Enter OTKSL 3. The work MIN will be highlighted 4. Select the word CHANGE by selecting the top right button 5. Select DELETE. Press and hold the button until clear 6. Have the customer enter the 10 digit MIN number 7. Select OK with the top right button. The “User Activation” screen will appear 8. Scroll to highlight the CDMA Sys ID 9. Select CHANGE by selecting the top right buttonOriginally Posted by taoufik. display problem *#**367628#+send key master re *#**778337#+send key E2p reset O2x1 reset password *#9999# Hang talk and power button together [??]secret motorola mpx200 codes engineering menu, test mode, logs, etc. Enter in the top secret 'Engineering Mode' on your MPx200 entering: *#**364# on your keypad then press the Green Button other interesting codes are: * # * * 3 7 2 # FQC (test mode) * # * * 3 6 4 # Engineering menu * # * * 2 6 6 * 0 # Set as data COM port * # * * 2 6 6 * 1 # Set as log COM port * # * * 7 9 7 # Time to failure timer & Power down code * # * * 2 2 6 3 * 0 # Set to default Band * # * * 2 2 6 3 * 1 # Disable GSM Band * # * * 2 2 6 3 * 2 # Disable DCS Band * # * * 2 2 6 3 * 3 # Disable EGSM and DCS Band * # * * 2 2 6 3 * 4 # Disable PCS Band * # 9 9 9 # which displays the command log * # * * 8 3 7 # Version info (some roms doesnt have implemented) Remember guys play at your own risk ####c350 english languge##### menu setting 1 1 5 2 6 (T190, T191, T205) master code - 19980722 - 20010903 ********** P2K test menu: *#06#, menu, menu, 048263* Test comands: 32*116*1*0*0 - read phone code 32*118*1*0*0 - read security code 18*0 - factory reset, phone code off 18*1 - master reset 54*18*1 - full phone reset 10*0*6 - select 900/1800 32*279*1*0*8 - model 32*383*1*0*0 - flex version Hard reset MPX200, MPX220 - blue button + power on (T190, T191, T205) master code - 19980722 - 20010903 ********** P2K test menu: *#06#, menu, menu, 048263* Test comands: 32*116*1*0*0 - read phone code 32*118*1*0*0 - read security code 18*0 - factory reset, phone code off 18*1 - master reset 54*18*1 - full phone reset 10*0*6 - select 900/1800 32*279*1*0*8 - model 32*383*1*0*0 - flex version Hard reset MPX200, MPX220 - blue button + power on (T190, T191, T205) master code - 19980722 - 20010903 |
12-27-2010, 04:38 | #5 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: lapu-lapu cebu
Member: 1421076 Status: Offline Sonork: 100.1595996 Thanks Meter: 31 | Quote:
any body know how to reset into english language? or code to be press ............... | |
12-27-2010, 05:45 | #6 (permalink) |
Member: 1421076 Status: Offline Sonork: 100.1595996 Thanks Meter: 31 | problem solve turn-off phone then remove sim then turn-on again now phone back to english mode................. i search all furom but no solution yet so hope it can helps also.. i found same problem of my phone no solution hope it can helps... tested by me. br.msmhk_gsm |
BB5 3 UK codes / Vodafone UK codes / Motorola codes !!..Quick turnaround;) | fonesunlock | Main Sales Section | 0 | 03-12-2007 00:08 |
CXXX Clip,Sagem code reader,UST,Neelix3,Data1,Se-figther,Motorola codes - UK | STB Trading | Main Sales Section | 0 | 01-08-2004 10:33 |
CXXX Clip,Sagem code reader,UST,Neelix3,Data1,Se-figther,Motorola codes - UK | STB Trading | Main Sales Section | 0 | 01-07-2004 10:26 |
exhange 1 motorola code by 1 siemens code!! | infogsm | Exchange Section | 1 | 07-09-2003 12:08 |
S55 Code Exchange With 2 Motorola Codes | HEADMASTER | Phone Unlocking Codes & Maps | 0 | 06-07-2003 13:14 |
