Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
12-09-2008, 10:20 | #1 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | :: motorola Critical Errors Solutions :: :: Motorola Critical Errors Solutions :: Critical Error: 00 No solution, except you have previously made a backup Critical Error: 0A Internal Error: 0001 flash chip could not be found Critical Error: 01 1b Critical Error: 0x1DE RSA active protection Critical Error: 0xDAB PDS repair and full Flash Critical Error: DE AD PDS damaged area PDS Repair critical error: DE / CA Critical Error: 01 13 Critical Error: 8 Error: B8 Flash chip damaged, no communication with the Processor TP was not properly implemented Critical Error: 9A TP must be connected occurs at PDS repair Critical Error: 10 39 The boot loader in flash file is not the same as flash file Critical Error: 11 35 Usually fixed by flashing firmware. Critical Error: 19 87 Critical Error: PDS zone is damaged, TP and connect via PDS repair, than Flash Firmware Critical Error: 80 40 TP is necessary Critical Error: 80 42 TP is necessary Critical Error: 81 10 TP is necessary Critical Error: 82 3F Critical Error: 82 15 Critical Error: 82 41 Critical Error: 82 14 TP is necessary Critical Error: 84 PHONE CODE SIG ERROR: PDS repair and Flash Firmware MEM_MAP Blank Service Required: PDS repair and flash with Flash Firmware higher as was previously Error Jump command in RSD / PST / etc boot loader too high or too low loader flash file Boot loader 0x200, 0x300, etc Boot loader corrupt new PDS install and repair. |
The Following 21 Users Say Thank You to dr_moosavi For This Useful Post: |
-:: N95-8gb latest solution ::- | NAVEED74 | Nokia Hardware & Hardware Repair | 36 | 11-11-2010 05:58 |
::.:: Nokia 6300 all solution ::.:: | amar181 | Nokia Hardware & Hardware Repair | 19 | 09-15-2009 18:02 |
..:: N72 charging problem solution ::.. | ..::Sunil::.. | Nokia Hardware & Hardware Repair | 2 | 06-16-2007 08:44 |
..:: Motorola Z3 - Successfully Unlocked ::.. | Sandman | Motorola P2k | 13 | 04-27-2007 13:43 |
