Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
06-22-2010, 08:01 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Online
Member: 1024090 Status: Offline Thanks Meter: 1,175 | Motorola FlipOut Hard Reset by(anowar_virus) To Hard Reset Motorola FlipOut. 1. Turn the power off. If your Motorola FLIPOUT is frozen, pull the battery out and reinsert it 2. Press and hold the Power and Camera buttons 3. Release the Camera button when prompted 4. Press and hold the Volume Down key 5. A yellow exclamation will appear on the display 6. Select the Wipe data/factory reset (Alt + W) option If you selected YES, all data including third-party applications will be deleted . Once the wipe is complete, the phone will reboot to its factory fresh state. Done, your Motorola FlipOut Reset back from its original status |
08-11-2010, 09:19 | #2 (permalink) | |
Junior Member Join Date: Jul 2008
Member: 819343 Status: Offline Thanks Meter: 5 | Quote:
there is NO, i repeat NO camera button on the Flipout. does anyone know how to really reset this damn thing? | |
08-11-2010, 09:46 | #3 (permalink) |
Member: 819343 Status: Offline Thanks Meter: 5 | right found it after searching every menu on the phone, the real way to hard reset this device is; 1). Press Menu 2). Press Settings 3). Press Privacy 4). Press Factory Data Reset. |
The Following User Says Thank You to tony666 For This Useful Post: |
01-14-2011, 21:36 | #4 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: Alex,EGYPT. Age: 51
Member: 16449 Status: Offline Thanks Meter: 39 | Quote:
sooo what u will do if the phone has phone lock?? need to make hard reset and no camera botum?? smart ask need to replay regards galaxyGsm | |
01-15-2011, 00:18 | #5 (permalink) | |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | Quote:
Maybe you mean soft reset ?? But Topic Title called Hard Reset , !!!! Thanks Mr Kamal Galaxy , Regards, | |
03-10-2011, 22:19 | #6 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1279162 Status: Offline Thanks Meter: 2 | source: Passo a passo hard reset Motorola Flipout ( MB511 ) Step by step hard reset Motorola Flipout (MB511) After spending a difficulty with this device, I decided to create manual with detailed instructions ... Hope that helps! FOOTSTEPS HARD RESET Motorola Flipout (MB511) With machine OFF precione simultaneous keys POWER + X ". Image will appear as shown below = Tap the POWER key to access the menu ANDROID RECOVERY SYSTEM as shown below, then using the navigation key to go in 4th option (WIPE DATA / FACTORY RESET) Confirm with ENTER key Confirm RESET OBS.: I used this option to remove user code, but as it looked forward to the client that the information contained in the device with this method will be totally lost. After RESET, return to the SYSTEM RECOVERY ANDROID menu, select option 1 (SCARE REBOOT NOW) The device was restarting in normal mode with the factory configuration. |
The Following 2 Users Say Thank You to golesorkh_11 For This Useful Post: |
10-07-2011, 06:08 | #7 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1668474 Status: Offline Sonork: jeannie llewellyn Thanks Meter: 0 | Thank You, golesorkh_11! This totally worked - we tried for over two weeks to unlock the moto flipout, and when we couldn't we were given the same printouts as below - pretty useless if the "camera button" isn't obvious, nor was it USED! Your solution was "right on!" Thanks for your intelligence! Jeannie and Amy |
03-20-2012, 17:42 | #9 (permalink) | |
Freak Poster Join Date: Sep 2005 Age: 42
Member: 178155 Status: Offline Thanks Meter: 15 | Quote:
03-28-2012, 15:18 | #10 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Online Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
Thanks For Your Kind Information / I Try Your Recommended All Procedure But All is Done. When I inset Any gsm sim Card in My Set few time latter Show Wi Fi Re-try Connection, When Press Cancel After Show On Dish-ply Left-Side Emergency Call / Right Site Stat Message. How to Solve This Problem. Thanks in Advance | |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
how can you reset the life timer without using a data cable for a 5125 TDMA phone? | PiNoY_bOy204 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-23-2001 12:46 |
HOW TO RESET SECURITY CODE IN NOKIA 6210 | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-26-2001 05:33 |
5190 patial flashes - why are they so hard to find? | Bads | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 04-14-2001 03:18 |
I have unlcoker for 51/61/32 for all new version for exchange Motorola 3*88 unlocker! | MC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-14-1999 13:02 |
