Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
06-20-2008, 15:36 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Madrid, ES. Age: 41
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | Motorola K1 Memory card -Unformatted problem i try to format i show: Format failed. Try Again? i try with another mmc same problem. i clean the place of mmc wich is with sim card place but same problem any idea pls? Thank you. |
06-20-2008, 15:49 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: (¯`». Catch Me If U Can .«´¯) Age: 35
Member: 553445 Status: Offline Sonork: 100.1585581 Thanks Meter: 8,184 | This Is Mobile Reader Ic Problem Change Than Try To Format |
The Following User Says Thank You to nasirkhan007 For This Useful Post: |
06-24-2008, 23:40 | #6 (permalink) |
Junior Member Join Date: Jun 2008
Member: 795617 Status: Offline Thanks Meter: 6 | Ok Amigo Primero Tenes Que Probar Con Otro Flex Si No Lee La Memoria Segundo Probas Con Otro Modulo Que Esta En La Pantalla O Si No Con El Modulo Que Lee La Memoria Eso Pasa Por Que Hay Humedad Y Genera Corto ... |
K1 Memory card not show | jakkarzoya_2511 | Motorola Hardware Repair | 0 | 08-24-2008 16:46 |
Memory card unformatted | nasirahmed | Motorola Hardware Repair | 0 | 01-22-2008 06:39 |
help me L7 Memory card Unformat | toan_bi | Motorola Hardware Repair | 1 | 05-01-2007 08:35 |
V360 Memory card Unformat | haider | Motorola Hardware Repair | 1 | 04-21-2007 13:17 |
help me V3i Memory card Unformat | f.i.t | Motorola Hardware Repair | 1 | 04-15-2007 23:35 |
