Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > Motorola Hardware Repair Section
Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing.
Old 01-22-2009, 01:44   #1 (permalink)
odetundun's Avatar
Member: 838671
Motorola L6 NETWORK PROBLEM.
Water damage motorola L6 fail to see network. please somebody show me with diagram how to solve this problem.
The Following 3 Users Say Thank You to odetundun For This Useful Post:
Old 01-22-2009, 02:07   #2 (permalink)
Member: 587083
hi
changes P.A ic
Old 02-05-2009, 19:26   #3 (permalink)
Member: 360191
use tuning nvm or master reset
Old 02-05-2009, 19:50   #4 (permalink)
taieeb's Avatar
Member: 781262
change the network cabel it works
The Following User Says Thank You to taieeb For This Useful Post:
Old 02-08-2009, 09:24   #5 (permalink)
Member: 960928
Sonork: 1
Question charge cards
Can a debt consolidation loan eliminate your credit card debt? A consolidation loan might (or might not) be the key. There are several things you must consider when making the choice to consolidate debt using a debt consolidation loan.First, is a debt consolidation loan your best choice to eliminate or substantially reduce your debt? There are other options available to you, including credit counseling and bankruptcy. Obviously bankruptcy is a last resort. You must examine several factors when making your decision on which debt reduction / elimination strategy to use. You need to get information on debt consolidation to make the correct decision.?How much outstanding debt do you have??What is the interest rate of your current debt? Many credit cards have interest rates of 14% - 22%, depending upon your credit rating and payment history. Obviously, the higher your current average interest rate, the better off you will be if you consolidate your debt with a consolidation loan at a much lower rate.?How much of your outstanding debt is unsecured? Unsecured debt has no collateral against it. Credit cards, student loans, store charge cards and medical bills are examples of unsecured debt. If you have over $7,500 in unsecured debt there a multitude of lenders that you can look at. Student loans fall into a different classification from other types of unsecured debt. In the United States, most are backed by the federal government. Usually you will have to use a secured debt consolidation loan to pay off your unsecured loans. You may also be able to refinance your secured debts, but you usually cannot consolidate secured debts.?Do you own a home or other substantial assets to use as collateral for a debt consolidation loan? If you own a Home or other real estate, how much equity do you have in it??What type of interest rate is available to you for a consolidation loan? The interest rate you receive on your loan is affected by a multitude of factors including the prime rate. For student loans, maple story mesos the borrower interest rate on consolidation loans is currently calculated as the weighted average of the interest rates in effect on the loans being consolidated, rounded up to the nearest one-eighth of 1 percent. They are capped at 8.25 percent.?How is your credit rating? Someone with a very good credit score has options open to them that those with wow power leveling lesser credit ratings do not.Keep in mind that if you have more than 20% equity in your home, you are usually not required to carry private mortgage insurance (PMI). If you have reached the 20% equity stage through either paying down the principal, asset appreciation, or both, you can probably drop PMI and lower your payment. wow power leveling On the flip side, if you are not paying PMI and you take out a consolidation or other Home equity loan, you may put yourself back under the 20% equity threshold. This would require you to get a new PMI policy. Factor this in when making your cost / benefit analysis.If you are constantly slipping backward and your cash flow is poor, you can improve things with a debt consolidation loan. Be careful and weigh your options carefully. Take into account the tax benefits archlord gold you may receive by using a Home equity loan to consolidate your debt. This benefit will vary depending upon your tax rate. You can get many free quotes for debt consolidation loans. There are several places that have multiple lenders compete for your Business. Talk to several lenders to see which will give you the most favorable terms. You can substantially lower your monthly payment buy archlord gold and significantly improve your cash flow situation with a debt consolidation loan. Just make sure this is the right choice for your needs.
Old 02-10-2009, 06:00   #6 (permalink)
Member: 243114
pls solution pls ...............bharat.....
Old 02-20-2009, 04:49   #7 (permalink)
Member: 774938
generaly not solve , just little heat net section
Old 02-20-2009, 05:22   #8 (permalink)
.:JOAB:.'s Avatar
Member: 725927
Posible solution for you, tested many times.
Resold all the components in the impedance matching network after watch de board with water and detergent, tested and work in 80% of the cases.
Good Luck
The Following User Says Thank You to .:JOAB:. For This Useful Post:
Old 02-24-2009, 02:53   #9 (permalink)
Member: 609663
solution
http://www.4shared.com/file/89179497...ervicio_1.html
The Following 4 Users Say Thank You to edgar velasquez For This Useful Post:
Old 01-18-2010, 09:40   #10 (permalink)
Member: 1130434
Sonork: simplenkd
thanks............................................ ....................
Old 10-31-2010, 18:43   #11 (permalink)
Member: 885980
Sonork: apuapu
thanks for need full help
Old 11-03-2010, 08:23   #12 (permalink)
Registered User
Member: 1343305
I forgot my unlock and security code for...
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website ***************** which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
____________________
nokia lcd|htc spare parts|samsung spare parts
|motorola spare parts|nokia parts
Old 11-03-2010, 08:57   #13 (permalink)
Registered User
Member: 1343305
Problem with the Motorola L6 Cellular Phone
As far as I know free codes does not unlock your phone, so even if you would find a unlock code or whatever you'd have to spend some money.
I would recommend the ***************** site is nearly perfect and they were recommended highly in the cell phone forums.
Hope this helps.
___________________
nokia parts
Old 09-23-2011, 20:32   #14 (permalink)
Member: 905027
Sonork: 833102
great idea sir jee thanks
L6 network problem amar181 Motorola Hardware Repair Section 11 09-26-2009 09:34
L6 motorola low network problem mavi0249 Motorola Hardware Repair Section 1 08-27-2009 07:43
L6 Network Problem jamohaki Motorola Hardware Repair Section 6 06-07-2008 22:03
l6 network problem owoeye Motorola Hardware Repair Section 2 05-06-2007 15:21
L6 network problem kendevil Motorola Hardware Repair Section 3 11-07-2006 09:47
Page generated in 0.56634 seconds with 11 queries
