Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
02-25-2008, 10:59 | #1 (permalink) |
Crazy Poster Join Date: Oct 2005 Location: Pakistan Age: 37
Member: 195308 Status: Offline Sonork: Lover Thanks Meter: 20 | Motorola L7 invalid battery Thanks in Advance please paste solution with cler picture of main board. |
The Following 5 Users Say Thank You to evereastern For This Useful Post: |
02-27-2008, 06:58 | #3 (permalink) |
Member: 195308 Status: Offline Sonork: Lover Thanks Meter: 20 | For L6i Brother Try this.For L6i and it is 100% solved otherwise change the there charging ic near power ic will solve it. |
The Following 7 Users Say Thank You to evereastern For This Useful Post: |
05-31-2008, 19:18 | #6 (permalink) |
Junior Member Join Date: May 2008
Member: 772784 Status: Offline Sonork: emykendona Thanks Meter: 2 | --------------------------------------------------------------------------------I have motorola L7 after flash it shows invalid battery.i have ****ed all mobile hardware pictures problem but i can't find clear and proper solution to solve this problem. i tried last two days but not it is solved yet. Please give me a solution that can make it ok.Thanks in Advance please paste solution with cler picture of main board. |
The Following 2 Users Say Thank You to emykendona For This Useful Post: |
05-31-2008, 20:30 | #8 (permalink) |
No Life Poster Join Date: May 2006 Location: I Love Walking In The Rain Bec
Member: 276151 Status: Offline Sonork: 100.1577032 Thanks Meter: 234 | thanks ?????????????????????????????????????????? |
The Following 2 Users Say Thank You to FEATURE GSM™ For This Useful Post: |
06-21-2008, 14:06 | #9 (permalink) |
Junior Member Join Date: Apr 2008
Member: 757957 Status: Offline Sonork: 555025 Thanks Meter: 4 | l7 invalid battery help my l7 display invalid battery ..any body have its solution i m becoming mad of it.. |
The Following 4 Users Say Thank You to kriguru For This Useful Post: |
11-13-2008, 22:16 | #12 (permalink) |
Insane Poster Join Date: Oct 2006 Location: RSA
Member: 361967 Status: Offline Thanks Meter: 4 | Heat & tap oudio ic Put more flux on oudio ic power ic is one thing&heat it for1.2minuteswhile heating tap a little bit on one side that is it if continues change ic |
The Following 2 Users Say Thank You to BSI-3G For This Useful Post: |
11-25-2008, 11:27 | #14 (permalink) |
Junior Member Join Date: Nov 2008
Member: 893267 Status: Offline Sonork: Diamond2008 Thanks Meter: 3 | we will solve it! Invalid battery problems caused by the second pin of battery connector on the board. first make sure that connector is ok. if it's ok get schematics from here http://www.shrak-mobile.com/eng/schem_motorola.html then search for VR514 (which provides bayas voltage for battery recognition) and replace it with a new one. i couldn't upload the picture but hope it will work for you. i'll try to upload pic later |
The Following 2 Users Say Thank You to Diamond 2008 For This Useful Post: |
HOT MOTOROLA L7 invalid battery 100% solution | sulai2k | Motorola Hardware Repair | 8 | 02-21-2012 10:33 |
L7 invalid battery,pls help..... | jimmyyew | Motorola Hardware Repair | 27 | 05-16-2011 07:10 |
motorola L7 invalid battery | playboy4life | Motorola Hardware Repair | 4 | 10-03-2009 14:30 |
L7 Invalid Battery After Unluck Please Help | aang | Motorola Hardware Repair | 2 | 10-06-2006 09:41 |
L7 Invalid Battery | street | Smart-Clip | 4 | 05-05-2006 13:45 |
