Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
02-02-2009, 10:09 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2007 Location: In the web Age: 37
Member: 622382 Status: Offline Thanks Meter: 201 | motorola l7 on ring sound |
The Following User Says Thank You to shaheb_anl For This Useful Post: |
04-16-2009, 14:23 | #8 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1011078 Status: Offline Thanks Meter: 0 | Apple has released another beta of iPhone OS 3.0. While it appears to be relatively stable, Apple will have its work cut out to clear up the remaining issues in order to have it ready to launch with new hardware this summer. With it you can watch live ESPN broadcasting easily. You can use a DVD to iPhone converter for Macto enjoy HD DVD on iPhone OS 3.0. One of the best features of iPhone OS 3.0 is the EA game inside it. It can invoke the ringtone of the iphone made by iPhone Ringtone Maker for Mac iPhone OS 3.0 beta 3 has a number of issues to patch up before the OS is ready for public consumption. Still, developers familiar with the betas concurred that 3.0 is far better than 2.0 so far, which wasn't particularly stable at launch and required a major point update to 2.1 before many users felt comfortable. Judging from the few API changes and the current stability, Apple should be on track to have the new OS ready in time for this summer's expected iPhone hardware update. For some people it will not be late to enjoy HD video on iPhone. Video, favorite Video, iPhone Video Converter for Mac, iPhone OS 3.0. All is OK. Let’s look forward to its coming in this summar. |
05-07-2009, 04:38 | #9 (permalink) |
Junior Member Join Date: May 2009
Member: 1025971 Status: Offline Thanks Meter: 0 | iPhone ringtone maker for mac iPhone ringtone maker for mac can convert almost all mainstream video/audio formats including AVI, MPEG, WMV, DivX, MP4, H.264/AVC, AVCHD, MKV, RM, MOV, XviD, 3GP, WMA, WAV, RA, M4A, MP3 to M4R iPhone ringtone, and transfer the converted ringtone to iPhone directly without iTunes after conversion if you want. |
05-07-2009, 06:47 | #10 (permalink) |
Member: 1026017 Status: Offline Thanks Meter: 0 | iPhone Ringtone Converter!!! iPhone Ringtone Converter is a powerful ringtone maker for iPhone, turns your dream come true that convert MP3 to iPhone ringtone, make M4a as iPhone ringtone, change AAC to your own iPhone ringtones and convert iPhone ringtone from all popular video/audio file formats like WAV, WMA, AAC, MP3, WAV, MIDI, AIFF, OGG, protected music purchased from iTunes store, M4P, M4B, M4V, FLV, 3GP, AVI, WMV, MP4, MPEG, etc. Download ringtone converter for iPhone for free now!!! Here is a guide on "how to make an iPhone ringtone" Step-by-step Guide: Firstly, Free download iPhone ringtone converter, run it in your computer Secondly, Load your music files by click"Browse" button Thirdly, Allows you to select a segment of audio files by drag the"start slide" and "end slide". Note:You can listen and pre-listen the music before convert Remember to specify a local ouput folder to save your output files by click"Browse" button in the middle of the interface. Forthly,If you want to transfer files to iPhone direcltly, you can check before"Export to iPhone". Fifthly, Just press"Generate" button to let it work! Sixthly, Done, enjoy files on iPhone now! |
07-08-2009, 08:51 | #11 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1070113 Status: Offline Thanks Meter: 1 | Have been looking for a way to make your own iPhone Ringtone? Now with the released of iPhone Ringtone Creator for Mac and iPhone Ringtone Converter, no matter you are Mac or Windows user, make your own unique iPhone Ringtone is so easy! ********* iPhone Ringntone Maker for Mac provides the easiest and quickest way to create iPhone ringtone from video or music and transfer it to your iPhone directly. This Mac iPhone ringtone maker software supports converting almost all video/audio formats to M4R files and trimming video/audio to make the most colorful clip as your iPhone ringtone. It allows you to trim video/audio file and convert any preferred segment to iPhone ringtone. After making iPhone ringtone, the iPhone ringtone maker for Mac can directly transfer the M4R file to your iPhone as iPhone ringtone. Key function of these two iPhone Ringtone Maker 1. Convert music or audio files of any format to iPhone ringtoneAlmost all audio formats are supported including MP3, WMA, AAC, WAV, OGG, M4A, RA etc. You can easily make your own ringtone for iPhone. 2. Convert videos to iPhone ringtoneIt helps extract music from videos to M4R ringtone. The video formats supported include AVI, MPEG, WMV, MP4, FLV, MKV, H.264/MPEG-4, MOV, RM, M4V, VOB, ASF, 3GP, QT, MPV, etc. 3. Trim input file to get a clip to convertIf you only prefer the most colorful music segment, then just drag and drop to get the segment and turn it into iPhone ringtone. 4.Directly transfer ringtone to iPhoneThere is no need to launch iTunes, just check Export to iPhone and it will automatically transfer the converted files to iPhone after the converting. 5. Build-in PlayerTo help you check the music clip is just the very part you want, the Mac iPhone ringtone creator provides a built-in player to play it before converting. 6. Edit your RingtoneUsing iPhone Ringtone Maker for Mac, you are free to edit the added iPhone ringtone by removing it or renaming it directly. |
The Following User Says Thank You to annablack For This Useful Post: |
Samsung E490 no sound on ring and mp3 | Unicom | UST Pro II | 11 | 05-21-2011 14:46 |
motorola L7 on/of | sia_hassan | Motorola Hardware Repair | 0 | 03-19-2009 18:37 |
Motorola l7 on off key not working need jumper solution | vishalhkothari | Motorola Hardware Repair | 0 | 12-30-2008 09:11 |
How to open up the metal cover on a Motorola L7... | joerome | Smart-Clip | 10 | 03-25-2006 03:29 |
Ringing Sound Disappeared in Handsfree set on Motorola V300 | ladinaeng | Motorola P2k | 0 | 09-21-2004 15:48 |
