Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing. |
| | #319 (permalink) |
| Junior Member ![]() ![]() Join Date: Feb 2008
Member: 714492 Status: Offline Thanks: 13
| Motorola Codes Here. ~FIROZ~Motorola L6: ------------ hold * 65512890 for reset hold * 5806 sw version hold * 487989 NS lock menu hold * 482896 CP hold * 574243 NS hold * 967678 SP hold * 362628 IMSI hold * 787090 Lock net level hold * 787292 Lock net level Reset L7 security code without any cable --------------------------------------- press menu button enter 6 time 0 and then press ok *#06# IMEI in permament test mode (* hold 2 sec) ***113*1*[OK] net monitor T205/T19x (ACER) *#300# OK List the Software and Hardware version *#301# OK Full Keypads functional Test *#303# OK Set Default Language to English *#304# OK Set OFF engineering mode #304*19980722# OK Set ON engineering mode *#305# OK Location: 1 OK *#307# OK Engineering Test Mode *#311# OK Phone code changed to default code *#400# OK ADC, Cal val* *#402# OK Adjust Display Intensity / Contrast *#403# OK List the Manufacturing Informations 19980722 OK Master Unlock code for Phone and Sim Lock *#302# OK Acoustic test* 7.1 Greeting 7.2 Main VlmGain 7.3 Input Cal 7.4 Output Cal 7.5 Side In Gain 7.6 Vox Gain 7.7 Min Mic Engy 7.8 More (a) In Vlm Gain (b) Aux Vlm Gain © Silence Prd (d) Supp Prd (e) In Volume (f) Out Volume (g) Icon (h) Image (i) Animation *3370# EFR ON (enhanced full rate) #3370# ERF OFF *#72837726# OK Confirm ?, Data saver 1234 OK Phone code default *#0000# OK Setting saved, restore set phone do default language *#0048# OK Fast change polish langpack *#0007# OK Fast change russian langpack MOTOROLA 3xx *#06# and quick 'menu-key' and 048263* (Push the key quickly!) and entering at field "OPTCODE" you must try several times. If not working try with MOTO TEST CARD inserted. Security code - 32*118*1*0*0 Model - 32*279*1*0*8 Flex ver - 32*383*1*0*0 Master Reset - 18*0 Master Clear - 18*1 Set band GSM 900 - 10*0*3 Set band DCS 1800 - 10*0*4 Set band PCS 1900 - 10*0*5 Set dual band GSM 900/1800 - 10*0*6 Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/ Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/ 47*4*1*0*9*081A32547698103254 => IMEI=123456789012345 |
| The Following User Says Thank You to ~FIROZ~ For This Useful Post: |
| | #321 (permalink) |
| :: MOTOROLA :: firmwares smart clip flashs here Post by ~FIROZ~ ![]() smart clip flashs here http://downloads.gsmsandwich.com.ph/...lip/Flash_File |
| | #322 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Sep 2009 Location: kenya
Member: 1110490 Status: Offline Sonork: hardknock Thanks: 2
| have got this motorollla c139 phone . it alwaya show battery low even when battery is full and phone powers of. same battery works ok in another phone. which componenet would probably cause this. quite desperate hell |
| | #325 (permalink) |
| Junior Member ![]() ![]() Join Date: Dec 2008
Member: 919577 Status: Offline Thanks: 12
| | #330 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: Ukraine
Member: 615849 Status: Offline Thanks: 23
| V9 schematics http://depositfiles.com/files/huc9vgoet V8_L12_05-29-07_sm http://depositfiles.com/files/7xmhl8lb8 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Nokia Mobile Schematics | ..::ArchitRaj::.. | Nokia Repair Guide and FAQ | 139 | 02-20-2013 11:05 |
| New site for Mobile Schematics | serviceic | GSM Mobile Links | 55 | 07-23-2011 15:28 |
| Need the link for all mobiles schematic!!!!! | taihv | Nokia Hardware & Hardware-Repair Area | 3 | 11-14-2010 16:02 |
