Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > Motorola Hardware Repair Section
Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing.
Old 07-26-2011, 07:39   #1 (permalink)
palashtelecom's Avatar
Member: 1472596
Motorola Secret Codes
Motorola L6:
hold * 65512890 for reset
hold * 5806 sw version
hold * 487989 NS lock menu
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
hold * 787090 Lock net level
hold * 787292 Lock net level
Reset L7 security code without any cable
press menu button enter 6 time 0 and then press ok
*#06# IMEI
in permament test mode
(* hold 2 sec)
***113*1*[OK] net monitor
T205/T19x (ACER)
*#300# OK List the Software and Hardware version
*#301# OK Full Keypads functional Test
*#303# OK Set Default Language to English
*#304# OK Set OFF engineering mode
#304*19980722# OK Set ON engineering mode
*#305# OK Location: 1 OK
*#307# OK Engineering Test Mode
*#311# OK Phone code changed to default code
*#400# OK ADC, Cal val*
*#402# OK Adjust Display Intensity / Contrast
*#403# OK List the Manufacturing Informations
19980722 OK Master Unlock code for Phone and Sim Lock
*#302# OK Acoustic test*
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy
7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
*3370# EFR ON (enhanced full rate)
#3370# ERF OFF
*#72837726# OK Confirm ?, Data saver
1234 OK Phone code default
*#0000# OK Setting saved, restore set phone do default language
*#0048# OK Fast change polish langpack
*#0007# OK Fast change russian langpack
MOTOROLA 3xx
*#06# and quick 'menu-key' and 048263* (Push the key quickly!)
and entering at field "OPTCODE" you must try several times.
If not working try with MOTO TEST CARD inserted.
Security code - 32*118*1*0*0
Model - 32*279*1*0*8
Flex ver - 32*383*1*0*0
Master Reset - 18*0
Master Clear - 18*1
Set band GSM 900 - 10*0*3
Set band DCS 1800 - 10*0*4
Set band PCS 1900 - 10*0*5
Set dual band GSM 900/1800 - 10*0*6
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/
Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change IMEI
The Following User Says Thank You to palashtelecom For This Useful Post:
Old 07-26-2011, 13:23   #2 (permalink)
Crazy Poster
Member: 1623488
Thank you friend!!
Old 09-06-2011, 17:52   #3 (permalink)
Member: 1649927
Cell phone challenged
More Info on changing the IMEI plzzzzzzzzzzzzzz
Motorola v635 need this phone bad as I am on disability and cant afford another... It was balcklisted some 5 years ago or so.
Thanks in advance.
Old 09-08-2011, 12:47   #4 (permalink)
Member: 1505080
how about newer model like v8...is there any?
PIN1/PIN2 CODE Jon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 12-26-2012 03:40
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 05-10-2012 14:14
5110 Security Code Help! cahrisma Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-05-2010 09:04
Orange IL, Nokia 5110 GSM codes... rosso11 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-05-1999 20:38
Pin Code Verdonn Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-23-1999 15:35
Page generated in 0.39340 seconds with 11 queries
