Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2006 Location: Zambia Age: 24
Member: 272581 Status: Offline Sonork: 100.1606685 Thanks: 32
| Motorola v360 power problem I received a moto v360. It was not powering on and the owner doesnt know what happened. i saw some mud on the main board so i washed it in spirit. after drying it, it powered on but after switching off and puttin on charger, the phone will not power on. So i heated the component on the board for a few minutes, i tried powering on and it could power on, after putting on usb cable on pc and switching off, the phone will not power on after pressing power button. I left the phone alone for 1 day, i tried pressing power button and it worked, after switch off, on, off, on, off, then it again fails to power on. What could be causing this problem? |
| | #4 (permalink) |
| Major Poster ![]() ![]() Join Date: Nov 2008
Member: 905846 Status: Offline Thanks: 15
| I think the owner dropped it in the puddle of mud. Forget about the spirit and alcohol, when you suspect a water damage use "JELT". (it removes oxidizers better then spirit but more expensive). If you suspect the phone was in the water, put it in alcohol (If you don't have Jelt or other anti-oxidizer). And then reheat the entire PCB with Steinel-like heat gun and lot's of flux. ![]() 350C if it's lead-free, or 290 if it's leaded tin. ****WARNING!!!! Do not heat with steinel glued BGA's!!!***** For me this technique fixes 70-80% of water damaged phones. |
| The Following User Says Thank You to Hells_Angel443 For This Useful Post: |
| | #6 (permalink) |
| Thanks guy, i fixed the phone and its working fine..bt now i have messed the signal...the phone is showing signal but it cant make calls..i have tried flashing but still the same problem...sometimes the signal is showing but sometimes its going off...what component should i fix now? please assist with pictures |
| | #7 (permalink) |
| [quote=Hells_Angel443;4117508] ****WARNING!!!! Do not heat with steinel glued BGA's!!!***** quote] bro what does this mean? and what happens if you heat glued BGA |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Motorola v360 power switch not work | sunnyarora | Motorola Hardware Repair Section | 0 | 11-28-2008 07:30 |
| Motorola v360 keypads problem please | toptech | Motorola Hardware Repair Section | 3 | 11-21-2008 08:43 |
| Motorola V360 Keypad problem!!! | xela09 | Motorola Hardware Repair Section | 6 | 05-15-2007 11:57 |
| Motorola V360 Unlock Problem w/ Bootloader 08.D.0 | fmescoto | Smart-Clip | 3 | 05-26-2006 10:29 |
