Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Motorola > Motorola Hardware Repair Section
Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing.
Old 09-01-2005, 21:53   #16 (permalink)
Member: 97043
motorola v3 power button not responding if i power on the phone the power but wount have any function again even if i want to off the phone until i remove the battery,but every other thing in and on the phone are working fine, i have even opened and cleaned the phone but still no responce from the power button it only comes on ...please help me...
The Following 8 Users Say Thank You to segun For This Useful Post:
Old 09-03-2005, 04:53   #17 (permalink)
silveraxe's Avatar
Member: 166746
came right. fixed
Originally Posted by silveraxe
Hi
I have a V150, it is saying "Insert sim Card" (with sim inserted ofcos)
Has anyone got a solution for this please?
thanks in advance
Ok so everyone can benefit from this,
on the right hand top corner of the sim card connectors lies 3 diodes in a row horizontally, i changed two of them, phone is 100% now.
The Following 5 Users Say Thank You to silveraxe For This Useful Post:
Old 09-03-2005, 04:55   #18 (permalink)
silveraxe's Avatar
Member: 166746
i need help....
Im busy fitting a motorla c205 and a T190 LCD, they seem to be the same,
I cannot get the LCD cable to stick onto the pcb, everytime i apply heat it comes out somehow... can anyone please assist with this, as this is very frustrating for me when i cant get something right (which i got right before)
thanks
The Following User Says Thank You to silveraxe For This Useful Post:
Old 09-04-2005, 03:09   #19 (permalink)
Amartt's Avatar
Member: 115826
i need help....
thanks
Ok pal .Firts not use ordinarie souder iron point in this work use a 15 W souder
Is Preferible Antex and Flux paste
Use a plate tool to hold the screen ribbom put souder past or flux in all the video line then put the ribbom screm hold the ribbon and whit presion whit the Desruptor
And very carefull let a little down space in the ribbon flex to u can put the
sourder to hot the flux or souder past ( the sourder past mix whit the soulder line )ok is all
The Following 4 Users Say Thank You to Amartt For This Useful Post:
Old 09-05-2005, 00:07   #20 (permalink)
silveraxe's Avatar
Member: 166746
wow... what a detailed description.. thanks man.. its working now,
all is ok 100%
2) I have 4 t190's not charging, 3 of them i changed the block they are fine now
the last one is giving me trouble, i changed the block so now its recognising the charger and is charging for 4 seconds, then as soon as the light goes on it restarts charging process and does this for ever...
I changed every diode and charging controller at the bottom of the phone near charging block and changed the light controller on the front bottom of pcb (due to desperation lol) what can solve this, its still doing the same thing!
Old 09-05-2005, 00:16   #21 (permalink)
silveraxe's Avatar
Member: 166746
solution found
I found a solution on the forum:
will try it and post tomorrow...
reset eprom &
use this diagram...
File Type: jpg 100% solotion 191 charging solotion.JPG (61.7 KB, 11369 views)
The Following 24 Users Say Thank You to silveraxe For This Useful Post:
Old 09-07-2005, 17:53   #22 (permalink)
s1emens's Avatar
Member: 40602
I have a problem with C650 blank LCD. Phone work normally except for blank LCD. Already flashed with SmartMoto, change a new LCD. Got no clue at all. Any help?
BR,
s1emens
The Following User Says Thank You to s1emens For This Useful Post:
Old 09-07-2005, 21:06   #23 (permalink)
HAJGSM's Avatar
Member: 34710
Red face c333 speaker ways
sevgigsm,can you please send me pictures for motorola c333 speaker ways?the speaker sometimes work,and at times not.i have tried changing it but still the same problem
The Following User Says Thank You to HAJGSM For This Useful Post:
Old 09-07-2005, 21:56   #24 (permalink)
silveraxe's Avatar
Member: 166746
RE:
I have a c650, came in for LCD,
I fitted new LCD, phone is fine, loudspeaker is working fine, but the handsets speakers is not working at all and the speaker I tested its 100%.
any solution pls???
Old 09-08-2005, 16:19   #25 (permalink)
HAJGSM's Avatar
Member: 34710
i have searched new motorola hardware solutions,but didnt see my solution,c333 speaker ways.can anybody help me?
Old 09-10-2005, 11:17   #26 (permalink)
amitks_in's Avatar
Member: 111665
c-350 motorola only on/off button working no other button is working ! its not a water damage phone ! board is clean ! I removed the keypad sticker and check with tweezers ! still no button working ! I need solution plz !
Old 09-10-2005, 15:18   #27 (permalink)
Member: 123133
Sonork: 100.999
hi
i have a c975 .. in charging fault.. when we attach the charger into the mobile he shows charging but not save.. also mobile heat up when we try to charge it
any one have complete solution
Kuku
Old 09-10-2005, 17:48   #28 (permalink)
sanjeewa57's Avatar
Member: 170619
any one has motorola 3788 schematic plz upload it
Old 09-10-2005, 18:26   #29 (permalink)
Member: 6569
can anybody help me with c975 keypad not working, I think it has a matrix and that is not available in the market.
gsmsharing.
The Following User Says Thank You to gsmsharing For This Useful Post:
Old 09-11-2005, 08:00   #30 (permalink)
Member: 168352
can anybody help me 4 C-115 spk not working . changed d spk 3 times
new motorola hardware repaire tools Athie_dede Motorola Hardware Repair Section 0 03-22-2010 16:06
NEW IN STOCK: GENIE UNIVERSAL, NEW 2010 hardware version !!! Gobi Main Sales Section 0 11-07-2009 10:56
new motorola Hardware Repair rubel_chakaria Motorola Hardware Repair Section 1 07-27-2009 23:32
New nokia hardware collection in one pack+new flash files aleenasager GSM Mobile Links 4 10-24-2008 16:45
Need Motorola Hardware! drucrew Main Sales Section 0 02-15-2002 23:21
Page generated in 0.46797 seconds with 12 queries
