Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
06-10-2003, 14:18 | #3 (permalink) |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | 1) I have the same problem! I'm reset eeprom with eeprom from another good phone and then unlock again! But problem is the same! 2) backup battery is removed for few houers but problems is the same! solution? WBR |
06-11-2003, 01:44 | #5 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | @iqballk: Reset your phone's eeprom (as DrMobile said) means you need to run MS Tools and go to download section. There press SetE2P button. Don't forget to set model to MH and set correct database. |
06-12-2003, 07:02 | #9 (permalink) | |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | Quote:
Its not important to use MS Tools.. u can use any software which have option to reset eeprom or software. U can use KIMA cracked soft. or use Paderf T191 unlocker. etc. Best Regards, Wahab | |
I BUY ALL SOLUTION FOR MOTOROLA T191 | forum | Motorola ODM | 1 | 12-03-2003 08:12 |
Motorola T191 Dead After Xak. Wich Siemens/nokia Suport Flash From T191? | crossings | Motorola ODM | 5 | 11-24-2003 18:34 |
Motorola T191 Ringtone Problem Help!!!! | srinivas_r | Motorola ODM | 0 | 07-11-2003 08:18 |
motorola T191 sw problem | stribag | Motorola ODM | 0 | 04-17-2002 04:55 |
:( The v1.71 Motorola T191 = a T191 Motorola (acer) phone?? | alruus | Motorola ODM | 0 | 04-05-2002 16:15 |
