Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 11-08-2011, 22:34   #1996 (permalink)
Member: 1679845
need a sloution to my verizon motorola blur
well need to know how to get my verizon motorola blur to boot up pass white screen once i power it on cus nothing works at all it jus stuck there....?
Old 11-17-2011, 17:48   #1997 (permalink)
Member: 534772
Change the flex cable
Old 11-17-2011, 17:52   #1998 (permalink)
Member: 534772
The v3 needs to be unlocked, but it has a test point you need diagram to know how to do it
Old 11-19-2011, 07:42   #1999 (permalink)
Member: 1524022
Sonork: 100.1608738
Thanks Meter: 36
v3r restart after 10sec whit simcard
any solution plz
Old 11-26-2011, 10:13   #2000 (permalink)
Member: 1693665
Smile motorola u6 pebl balck
pls help me my u6 is asking for subsidy pasword can u help me i dn't know the password my imei no is:::356392005786075 pls help me
Old 12-30-2011, 12:58   #2001 (permalink)
Member: 1549821
Thanks Meter: 7
motorola mb525 microphone problem
Old 12-31-2011, 05:34   #2002 (permalink)
Member: 42456
Thanks Meter: 3
v3i showing bootloader only
@grenni
i have her a v3i that automatically displays the boot loader when bat is inserted. the display has this message:
Boot Loader
0A.30.
SW Version:
R47A_G_08.D8.85R
PHONE CODE SIG
ERROR:
Battery Low
Cannot Program
PLS NOTE THAT BATTERRY LOW CANNOT PROGRAM message is BLINKING.
IT CANNOT BE DETECTED EVERYTIME I CONNECT IT TO MY PC,, NO RECTION AT ALL ON MY PC. USUALLY WE CAN SEE THE MESSAGE NEW FOUND HARDWARE BUT IN THIS CASE IT DID NOT.
HOW CAN I CONNECT THIS TO MY PC?? PLEASE HELP
Old 01-20-2012, 01:58   #2003 (permalink)
zipikiki's Avatar
Member: 85182
Sonork: 1593854
Thanks Meter: 42
Motorola MB525
Hy
Any help please. I received one Motorola MB525 with strange problem:
After turn on phone work ok everthing work fine but when i press off only for lock the screen and phone block everithine. Touch not work and i need to remove the batery for phone work again but when i lock the screen touch not work anymore.
I flash the phone with rsd but always the same....
Portuguese help:
Ola pessoal
Recebi um Motorola MB525 com um problema estranho:
ligo o telefone e funciona tudo perfeito sem qulquer problema mas apos bloquear a tela o mesmo deixa de funcionar o touch. quando pressiono a tecla para desbloquear o aparelho o touch nao mais responde. Ai tenho que retirar abateria para voltar a funcionar. so que depois de ele bloquear o teclado o touch nao volta mais a funcionar.
Um problema estranho que nunca tive nenhum igual.
Ja flashei com a RSD mas continua igual.
Agradeco opinioes e ajuda
Abrašo
Old 01-31-2012, 06:03   #2004 (permalink)
Member: 1716852
Sonork: mandy
my v3x is shorted you have a solution and diagram to my problem
Old 02-11-2012, 09:52   #2005 (permalink)
Member: 1472001
problem in U9
Hi
I have U9
it boot for a few second then turn off and re boot always.
How can I solve this problem?
thank you in advance
Old 02-23-2012, 10:37   #2006 (permalink)
Member: 42456
Thanks Meter: 3
sir i have here motorola v235 that is hang on logo only. upon checking it, i found that its shorted. some capcitors may be the culprit but i dont have the diagram of this unit. can you help me please in locating the leaking capacitor or any components of this phone thanks in advance
Old 02-27-2012, 16:12   #2007 (permalink)
Dipankor-ctg's Avatar
Member: 1541551
Sonork: 100.1663842
Thanks Meter: 4,487
need motorola rokr e2 flash file
Old 03-10-2012, 23:04   #2008 (permalink)
kenecee's Avatar
Member: 772242
Sonork: 100.1640371
Thanks Meter: 43
pls I need w377g flash files urgently
Old 03-14-2012, 14:50   #2009 (permalink)
Member: 1728309
Sonork: mobile inn
Thanks Meter: 3
motorola v3 no display in lcd.. blank display
motorola v3 no display in lcd.. blank display.
plz send me its solution.... picture help plz..
waiting
Old 04-11-2012, 19:10   #2010 (permalink)
Crazy Poster
Member: 1177643
Thanks Meter: 27
only charging ic problem .
Post here any problem about Nokia keypad - key, and let me give you the solution stefani Nokia Repair Guide and FAQ 850 08-22-2013 13:05
Post me a problem in NOKIA and get it solved. Shmona Nokia Hardware & Hardware Repair 6 12-31-2007 09:17
Like allways, NsPro give you THE BEST, FASTEST and of chourse.. the REAL!!! solutions Elco NSPRO 73 04-25-2007 17:18
Page generated in 2.93893 seconds with 9 queries
