Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 11-07-2019, 19:03   #2146 (permalink)
$h@hidmobile$'s Avatar
Member: 652132
Thanks Meter: 146
moto z3 play touch do not work sometime after changing screen ,
Originally Posted by greeni222000 View Post
dear mates postme your problem in motorola handset then let me give you the true solution
hi , i change screen for moto Z3 play , now touch digitizer works sometime but when i restart the phone it do not work , it restart by itself several time then start work fine.
Old 11-15-2019, 15:05   #2147 (permalink)
bherkund's Avatar
Member: 1119917
Sonork: nedi
Thanks Meter: 190
i have moto xt1254 charging problem.....charging jack is ok,data cable is conneting to pc ok,charging symbol showing but not saving charging...i checked an other battery but same...when plugged charger symbol shows and in setting battery showing NOT CHARGE in status.....
please help me where is fault and how can i fix it...
Old 12-11-2019, 03:59   #2148 (permalink)
Member: 2938129
XT1254 (Droid Turbo)
Device was shattered, shortly after it stopped working. Now it's black screen, with what I presume a bootloop (vibrating every 2-3 mins). Any fix? Sounds like a watchdog timer is getting tripped, I wonder if shorting a pin to tell the device the screen does work will get it to boot. Honestly just want to get my files off it.
Old 01-08-2020, 12:21   #2149 (permalink)
Member: 136052
Thanks Meter: 75
Please help
Motorola G4 Plus ATHENE: XT1640, XT1641, XT1642,
After i change LCD and Frame and Touch complectic from aliexxx , phone not starting not boot ( if i put charge , I see lightning on the LCD , then screen fades and the phone not charge and does not turn on .
if hawe manuals or shem for G4 Plus please post
Old 01-15-2020, 04:23   #2150 (permalink)
Member: 1718709
Thanks Meter: 10
Moto xt1921-6 and xt1767 sudenly dead, phones are both news aparently, even board, battery ok, phones dont charge and dont have any component visualy damaged, dont turn on or recognized by pc in any mode, not quqlcomm 9008 or not recognized by pc.
its strange problem for mi, both phones have qualcomm processor.
Pls help bros!!! ;(
tx in advance!!!
Old 02-17-2020, 16:25   #2151 (permalink)
Member: 2059293
hi sir i have moto g4 plus ringer is working but ear speaker not working please help:
Old 04-11-2020, 14:43   #2152 (permalink)
Member: 1595996
motorola g6 plus dead........no usb detect in pc...plz help experts..
Old 08-13-2020, 13:02   #2153 (permalink)
Member: 2585125
hello there
i would like to purchase a Motorola IDEN unlock software
anyone can assist
i have a NCKdongle but the iden activation is no longer available
tq
anthony
Old 12-13-2020, 04:49   #2154 (permalink)
Member: 2826622
Question moto G4 plus
motorola G4 plus do not show enter unlocking code option.
I need to do carrier unlocking to use my sim card. even i dont know which carrier its locked to. please help.
Old 01-03-2021, 14:52   #2155 (permalink)
Member: 1018563
moto
Sir.....Moto G5s Network Problem Please help me
Old 01-24-2021, 23:18   #2156 (permalink)
Member: 2970434
hi i have mot c650 dead unit. i tried to flash using smart moto but it says connect phone first. anybody help?
Old 02-04-2021, 12:41   #2157 (permalink)
Member: 338239
Dear i have moto G5eplus 5pcs handset there have a charging problem , cannt store me battery (fake charging show) please help me when i will check with amp meter it will show load .250-.400 amp pls let me know what is solution and where is charging ic of that mobile
Old 05-12-2021, 18:04   #2158 (permalink)
Member: 2976927
Hello i got sime motorola xt1642 and xt1925 can unlock frp by octoplus frp unlock tool can u help ?
Old 05-13-2021, 22:29   #2159 (permalink)
rorcorporation's Avatar
Member: 1664131
Sonork: 100.1636755
Thanks Meter: 38
Moto g7 plus need charging ways
Old 02-24-2023, 02:37   #2160 (permalink)
Member: 3032834
Falla de imagen en g6 play/e5
Tengo un g6 play/e5 el cual al cambiar pantalla me empieza a fallar la imagen al igual que con su pantalla original, y veo que el voltaje del backlight está bien
Post here any problem about Nokia keypad - key, and let me give you the solution stefani Nokia Repair Guide and FAQ 850 08-22-2013 12:05
Post me a problem in NOKIA and get it solved. Shmona Nokia Hardware & Hardware Repair 6 12-31-2007 09:17
Like allways, NsPro give you THE BEST, FASTEST and of chourse.. the REAL!!! solutions Elco NSPRO 73 04-25-2007 16:18
Page generated in 0.23576 seconds with 11 queries
