Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
09-18-2006, 11:40 | #16 (permalink) |
Registered User Join Date: Jun 2006 Location: taguig,Philippines
Member: 300867 Status: Offline Thanks Meter: 2 | i have c651 & T191 no display.. the lcd is good, you can receive a call but no display.. any idea on how to repair this units? thanks! |
The Following 2 Users Say Thank You to overdrive O.D. For This Useful Post: |
09-19-2006, 20:47 | #17 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | I have a Motorola L6 phone. First I wanna Upgrade the version of the phone but I made a terrible mistake, I flashed the phone use L2 firmware NOT L6 firmware using Flash Backup v.3 Flashing procces successful but after that the phone won't turn on. I've Tried any kind of testpoint (version 1 and 2) with batery or external power supply BUT the computer still CAN NOT FIND / DETECT ANY "S BLANK NEPTUNE" !! Is there any way I can fix my phone now?!?? what should I do now??? Is it posibble if I erase the flash ic with labtool first and then flash the phone again?? |
09-22-2006, 18:53 | #19 (permalink) |
Crazy Poster Join Date: Jul 2006 Location: Goa India
Member: 310194 Status: Offline Sonork: techsolutiongoa Thanks Meter: 5 | dear Hatts just insert a hard plastic strip on the sides of the top flip and open it this flip up top is just pressed closed once u open it you will find the screws if u have any further problems PM me good li=uck |
09-23-2006, 11:55 | #20 (permalink) |
Junior Member Join Date: Nov 2005
Member: 202269 Status: Offline Thanks Meter: 0 | am having mot c115 with no network when i replace the pf it does not disply. i have tried different good pfs but still the prombrem persists. is trere a way i can tap the pf and the network be ok? thanks. |
09-26-2006, 21:49 | #21 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Near the sea... Portugal Age: 48
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | So where is the genious that was able to give solutions? I have a few questions but i wont bother ask them since noone is getting any awnsers!!!!!! |
09-26-2006, 21:53 | #22 (permalink) |
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | ei chevka, try too do a PDS repair and then full flash with ******* file from mss4. I think this will help you! post results......See you!! |
09-26-2006, 21:54 | #23 (permalink) |
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | But first try too fullflash with ******* File..... |
The Following User Says Thank You to bauzito For This Useful Post: |
09-27-2006, 12:22 | #24 (permalink) |
Junior Member Join Date: Jul 2003 Location: india Age: 71
Member: 35518 Status: Offline Thanks Meter: 6 | moto l6 no ringing sound i have moto l6 water logged working fine except ringing sound please help thanks in advance |
The Following 2 Users Say Thank You to param_commu For This Useful Post: |
10-01-2006, 12:37 | #27 (permalink) |
Junior Member Join Date: Sep 2006
Member: 360606 Status: Offline Thanks Meter: 1 | Hi,I have a problem with E398. Phone gets hot and drains batt quickly, even when not powered on. U900 chip is source of heat. Phone seems to work ok otherwise. Any ideas? |
The Following User Says Thank You to gl3nn For This Useful Post: |
10-08-2006, 21:04 | #28 (permalink) |
Junior Member Join Date: May 2006
Member: 279540 Status: Offline Thanks Meter: 1 | I have a motorola v525. It does not charge, i opened it up and on the inside i saw that the pins that connect the charging piece to the board are not attached anymore. How can i solve the problem. |
The Following User Says Thank You to Nally2k6 For This Useful Post: |
10-09-2006, 11:04 | #30 (permalink) |
Junior Member Join Date: Dec 2005
Member: 208107 Status: Offline Thanks Meter: 1 | my daughter has entered an unlock code in her v220 to stop other people accessing her phone but has now forgot the code. any solutions greatly appreciated.. tnx |
The Following User Says Thank You to b0nd For This Useful Post: |
Post here any problem about Nokia keypad - key, and let me give you the solution | stefani | Nokia Repair Guide and FAQ | 850 | 08-22-2013 12:05 |
Post me a problem in NOKIA and get it solved. | Shmona | Nokia Hardware & Hardware Repair | 6 | 12-31-2007 09:17 |
Like allways, NsPro give you THE BEST, FASTEST and of chourse.. the REAL!!! solutions | Elco | NSPRO | 73 | 04-25-2007 16:18 |
