Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 12-10-2006, 08:33   #121 (permalink)
Member: 202269
pliz assist on how i can bypass motorola c11 series pa and antenae switch
Old 12-10-2006, 08:40   #122 (permalink)
sabby_singh's Avatar
Member: 100376
Sonork: 100.1591842
Thanks Meter: 150
Originally Posted by greeni222000 View Post
dear mates postme your problem in motorola handset then let me give you the true solution
dear sir ,
I have a tempered c114 now there is no speaker voice even though the speaker is open, but no incoming voice.I have changed twl3025 but stil there is no incomin voice but it give the inner mic voice need help
br
Old 12-10-2006, 12:11   #123 (permalink)
Member: 405571
Thanks Meter: 9
i have here motorola L6 keypadlight problem.....can u give me any solution regarding this problem????thanks n advance...
Old 12-10-2006, 22:09   #124 (permalink)
Member: 338397
I have a motorola 3 V975, it says "Contact operator" when a insert a sim. Some one has loked my phone Unconsciously , Please help me to unlock
IMEI: 355886002193418 written inside.
Thanks
Hersi
Old 12-10-2006, 22:16   #125 (permalink)
Member: 338397
Thanks
Hersi
Old 12-10-2006, 22:30   #126 (permalink)
Member: 380144
tomtom keep freezing up while using on n80.
hi, i got tomtom6.1 on my nokia n80 activated on guam map but i switched it to GB map.evrything work fine but every now and then while tomtom running screen freeze up for minute or so then it will say no gps device found.then it automatilly search for gps device and find my bloutooth gps receiver.and work fine aagin .there is no pattern, it happen randomly..somwtimes 2/3 min or sometimesafter 10/20 min later...but does happen..
i got nokia n80 v3 software.
tomtom original blutooth receiver...
great britain map
plz help...
Old 12-11-2006, 01:33   #127 (permalink)
Member: 220143
Thanks Meter: 103
Originally Posted by pawansingh View Post
hi i unlock moto v980 the process was sucessesful but when iasssemble the phone it is not switching on the supply is also not there pleses help
I have similar problem with a V980M. After close observtion it seems that the test point resistor was damaged. Is it posibble to replace it using a resistor from another PCB? If so which one ? Please guid me with fix for this one
Thanks
Old 12-11-2006, 01:36   #128 (permalink)
Member: 220143
Thanks Meter: 103
Thanks
Hersi
My friend these phones has to be unlocked by Software..... Unless you contact your service provider for subsidy codes or a reseller who usually have copies of these codes from various operators.
my2cents
Old 12-11-2006, 06:18   #129 (permalink)
Member: 93214
Thanks Meter: 18
I Need Solution For L6 Hanging.. It Will Work For 2 ..3 Calls Againn It Will Hang.
Old 12-11-2006, 09:06   #130 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,871
motorola c-168 imei repiar help help
Old 12-11-2006, 09:26   #131 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,871
Old 12-12-2006, 00:10   #132 (permalink)
Member: 374714
Thanks Meter: 9
hi ihave v3r after unlouk the screen loader black what can i do
Old 12-12-2006, 01:36   #133 (permalink)
Cheater -Don't Deal with him-
infogsm's Avatar
Member: 18022
Sonork: 1574868
Thanks Meter: 192
l7 with insert sim any solution ?
br
Old 12-12-2006, 02:03   #134 (permalink)
Member: 393321
C651 with signal bt cannt be contact!!! please help
The Following User Says Thank You to jayine1127 For This Useful Post:
Old 12-13-2006, 00:18   #135 (permalink)
Member: 373605
Thanks Meter: 11
my misses has a vk530 and for some reason it has just stopped working when it is powered up the keys light up a but nohing else happens and the same when connected to the power , there is no screen power?
any ideas please?
Post here any problem about Nokia keypad - key, and let me give you the solution stefani Nokia Repair Guide and FAQ 850 08-22-2013 13:05
Post me a problem in NOKIA and get it solved. Shmona Nokia Hardware & Hardware Repair 6 12-31-2007 09:17
Like allways, NsPro give you THE BEST, FASTEST and of chourse.. the REAL!!! solutions Elco NSPRO 73 04-25-2007 17:18
Page generated in 0.35805 seconds with 9 queries
