Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
10-04-2007, 15:01 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Ghana-Ashanti-Kumasi
Member: 434980 Status: Offline Thanks Meter: 6 | V3 camera freezing phone |
10-05-2007, 19:55 | #4 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 36
Member: 85950 Status: Offline Thanks Meter: 2 | Open up the phones face plate and make sure the camera flex cable is has no slits, after make sure it is connected properly no dust etc. between connectors, power on the phone again and check if camera is working if not, if you have another razr lying around use this camera on there and see if it gives same problems if not then it must be something other then the camera, somewhere on the board, or the lcd, or the flex cable, you have to trouble shoot it out. |
01-05-2008, 17:43 | #8 (permalink) |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | Hi tyo all I have same pro with v3 phone freez when camera on so I try as some frends say to change camera but still the same also I remove camera from phone and its freez with or without camera At least problem was flex I chang flex phone work fine and tack photo |
D600 camera freeze | huzsolt | SWIFT Platform | 2 | 09-07-2006 15:10 |
sl65 camera freezes phone | petermov | Siemens Hardware Repair Area | 15 | 05-19-2006 11:33 |
p910i camera freeze solution ? | imran_k | Sony Ericsson | 1 | 03-30-2006 09:05 |
e800 camera freezing | alanmar | SYSOL Platform | 1 | 09-14-2004 13:50 |
T610 Camera Freezes | shaheed | Cruiser Suite | 3 | 04-05-2004 22:23 |
