Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
10-05-2007, 13:11 | #1 (permalink) |
Registered User Join Date: Aug 2004 Age: 44
Member: 76882 Status: Offline Thanks Meter: 56 | v3 crazy keypad (voice recording memory full)& no 2,4 automatic digits onnnnn. i changed flux but same prob. plz hlp me any one |
10-05-2007, 19:52 | #3 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 36
Member: 85950 Status: Offline Thanks Meter: 2 | I had similar problem changed the keypad flex, but that was not the problem, flash the phone gazillion time but that was not the problem, there is a damaged chip on the board, i forgot the exact chip which it was but if you search around the forum for schematics, good LUCK |
10-07-2007, 05:46 | #4 (permalink) | |
No Life Poster Join Date: May 2007 Location: "Alfa-Gsm"
Member: 507536 Status: Offline Thanks Meter: 75 | Quote:
Friend, your full solution is to change the audio flex, not the keypad flex one.- it should work normally, tested in a lot of phones, try and post your results mate. Regards ..::Alfa-Gsm::.. | |
10-08-2007, 02:08 | #6 (permalink) | |
Mate, you know V3 has two flex the 1 Main (keypad), the 2 is on the Lcd, this has the buzzer and buttons like Vol +, Vol -, Cam and Recording, this flex you have to replace. post results or questions bro.- Regards ..::Alfa-Gsm::.. | |
10-08-2007, 21:30 | #7 (permalink) |
Member: 85950 Status: Offline Thanks Meter: 2 | I understand i have a few Razrs still siting with similar problem i will try and post results, but i remember last time i was reading there was a post about some chips which you had to replace or something similar |
10-28-2007, 10:31 | #9 (permalink) |
Junior Member Join Date: Jan 2006 Location: hungary
Member: 218870 Status: Offline Thanks Meter: 0 | v3i Hi I have a problem, on V3i doesn't work the On/Off button and It is in profile mode. On Lcd seems the Alarm all the time. The flex has been changed,but still problem. Whats the matter? |
11-05-2007, 23:52 | #10 (permalink) |
Major Poster Join Date: Oct 2007 Location: Karachi
Member: 605750 Status: Offline Thanks Meter: 7 | brother i recieved v3 water dammage with key pad problem...and i replaced complete keypad pannel...but if i press any key pad button it shows up volume??????how it can possible?????plz tell meee...i will b very thankfull 2 u... |
11-06-2007, 15:29 | #11 (permalink) | |
Member: 507536 Status: Offline Thanks Meter: 75 | V3 Keypad problem Quote:
11-13-2007, 20:14 | #12 (permalink) |
Member: 605750 Status: Offline Thanks Meter: 7 | i tried it but new problem arrived...some button r working...and some are not...i tried also with change the keypad ribbon but still problem...i think its a board problem...what can i do bro???previous problem is solved...thanks... |
Z3 with crazy keypad | Helaman | Motorola Hardware Repair | 2 | 03-07-2011 21:18 |
KE970 crazy keypad | irfaN_vu | LG Hardware Repair | 1 | 02-10-2009 15:54 |
v3 crazy | direktor1 | Motorola Hardware Repair | 10 | 04-24-2008 11:02 |
7610 crazy Keypad | .::AkhavanGSM::. | Nokia Hardware & Hardware Repair | 2 | 08-02-2007 13:22 |
V3 no keypad light | haider | Motorola P2k | 1 | 08-09-2005 14:35 |
