Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
10-04-2007, 03:28 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Davao City
Member: 305365 Status: Offline Thanks Meter: 90 | V3 power problem help!! this is the description of memory after I entr in flash mode... Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... unable to retrieve flash id Phone group: V30x,V40x,V50x,V52x,V60x Reading OTP... error BC Warning: OTP read failed Incomplete chip identification, restore & write functions unavailable |
10-17-2007, 15:03 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Reading flash id... unable to retrieve flash id, this error in the log file shows that flash chip can not be rad properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
v3 camera problem help | bobselectrical | Motorola Hardware Repair | 6 | 04-12-2008 12:23 |
V3 Powering Problem | jaamejam | Motorola Hardware Repair | 0 | 09-01-2007 16:27 |
v3 patch problem help | muratcell | Smart-Clip | 3 | 03-15-2007 19:54 |
v3 power problem | TITO | Motorola Hardware Repair | 7 | 09-30-2006 18:58 |
Razr V3 memory problem - HELP! | catcher | Motorola P2k | 0 | 08-10-2006 12:20 |
