Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 03-01-2009, 07:07   #1 (permalink)
Member: 632595
Thanks Meter: 16
V3i battery drains soon
hi, i have a v3i and i had problem with the battery for long time, where after charging the battery fully it get drained with in few hours or in few calls.So i bought a new original BR50 battery and charged it fully.But the problem remains same.i check with the vender,he checked the battery and told me no problem in the battery, which works fine with other mobiles.i am using the same charger for L7,i dont have any problem with that mobile(L7).Please tell me what will be the problem in my mobile and how to solve it.V3i shows charging & charge completed after fully charged.SW version R47A_G_08.D9.75R,Flex GSPLQAT675UL07E
The Following User Says Thank You to myvicky For This Useful Post:
Old 03-06-2009, 16:56   #2 (permalink)
bluejack22002's Avatar
Member: 741453
Thanks Meter: 43
Maybe replecing the PA, or rehot.
Old 03-06-2009, 21:08   #3 (permalink)
Member: 905846
Thanks Meter: 26
disconnect the PCB from the V3i, then connect the battery to the PCB , and check what part heats up.
V3i have a usually problem in PA.
but also check the flex connector for corrosion.
Old 03-09-2009, 17:23   #4 (permalink)
Member: 632595
Thanks Meter: 16
sorry to ask what is PA do any one have Schematic diagram
Old 03-09-2009, 17:52   #5 (permalink)
Member: 632595
Thanks Meter: 16
do any one know how to check or service the board
Old 03-11-2009, 09:57   #6 (permalink)
Member: 632595
Thanks Meter: 16
After abservation i found that battery drains soon only when i make or receive calls otherwise battery status remains same.even i can play audio or vedio for long time.what will be the problem? how to solve it?
Old 03-11-2009, 10:20   #7 (permalink)
Registered User
Member: 185010
Sonork: alias-albertino
Thanks Meter: 170
your problem is from the battery just change it.
Old 03-11-2009, 11:03   #8 (permalink)
Member: 632595
Thanks Meter: 16
the vendor checked the battery and told me there is no problem with the battery because i already changed the battery two times as stating battery problem(warranty claim) ,now he gave me the battery after testing it with a test sticker from moto service center.moto service center persons want me to change the mother board they are not doing chip level service
Old 03-28-2009, 08:23   #9 (permalink)
Member: 632595
Thanks Meter: 16
hi anyone got solution for my problem
Old 03-28-2009, 08:53   #10 (permalink)
shuaib_kashish's Avatar
Member: 405715
Thanks Meter: 271
hi bro,
check shorting if shorting ,remove bluetooth module or replace bluetooth module.
try and post reply.
Old 03-28-2009, 13:45   #11 (permalink)
Member: 632595
Thanks Meter: 16
I am not a profetional, modding is my hobby.In which section i should check for short,do u have service manual for v3i
v3i rapid battery drain (battery OK) kamthor Motorola Hardware Repair 5 08-13-2009 03:11
3310 fast battery draining raivenz Nokia Hardware & Hardware Repair 2 05-18-2005 04:25
after dejan unlock battery drains quickly nab Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-12-2002 21:21
6210- battery drain?? F C Nokia Hardware & Hardware Repair 3 01-25-2002 21:24
5110 hardware prblem ( battery drain fast) Fai555 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 07-09-2001 03:06
Page generated in 0.18805 seconds with 9 queries
